Speed331
- Sean
- Jun 19, 2020
- Las Vegas, NV
- 2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
Just fixed mine with the metal collars and had the same issue. When tightened up and touching the frame the openers short out. Wrapped it in electrical tape and it works fine. Not a permanent solution, but will do until I get the plastic collars.@InvertedLogic
Only reason I can see for the issue is one of the wires has insulation damage and end result..... a short (metal collar)
I know for a fact that I did not nick the wires while doing the mod. I think there must be a connection in the visor that is touching the extention arm and causing the short at the frame.
