Sun Visor Fix
JayJay
Johnny
North Georgia
'20 JLR
blnewt
New Mexico
Just ask @cosine he knows!
Not sure, but might be best to go the next size down on that 2pc set. Since the ID is 5/16 and you clamp both set screws down it's still 5/16. The collar w/ the 1 set screw goes into the shaft so it secures into it. Might not get enough clamp pressure since my 5/16" single screw collar just slides over that visor shaft and is loose until that screw secures it.
Maupar
Kev
Norcal
'18 JLUR
that’s what I’m thinking as well, I ordered a 5/16 and 1/4 set. I will report back which one works best.
blnewt
New Mexico
Kojava
Bryan
Surprise, AZ
2019 JLU Rubicon
Thank you so much for this post! It was a great guide to fixing my own driver’s side visor.
I bought the Jeep used about 2 months ago and didn’t check the visor. First time I adjusted it, it fell and hung crooked and was no help at all, of course. This provided a great fix. I ended up using the split collar so I didn’t have to do as much with the wiring.
Appreciate the community help on this one!
Tactician133
Illinois
2018 Jeep Wrangler Sahara, 2016 Ram 1500
Link to split collar you used?
Kojava
Bryan
Surprise, AZ
2019 JLU Rubicon
I ordered one that 15/64” (don’t remember how I cam up with that one) but it was too small. I ended up running to Ace Hardware and purchased one that was 8mm. Fit great.
Those ought to do it. 8mm or ÂĽ" bore is the right size.
Good luck.
A correction to the above the visor tube diameter is .312", which is 5/16" or within an RCH unit of 8mm (.315"). Not 1/4" (.250").
Just an update. My original fix with the flat push on retainers is holding up after a year. I've used them like a rental car and swung them to the side and drove like that on a bouncy freeway. I believe the push on retainer has a much higher holding strength than collar-setscrew. But I get that its more work to de-pin the connector.
Jeep Wrangler JL Sun Visor Fix 20200118_163147
BTW, if you de pin, you can swap the red and yellow wire positions and get the garage door opener to work even when the Jeep isn't on. I hated that it didn't work once I shut the engine off. All other vehicles Ive owned, the built in garage door opener was powered all the time. It's a mod that is gratifying that I think about every time I push that button once I've parked and shut down.
But now my "vanity mirror" light doesn't work unless the engine is running. I'm going thru withdrawls of not being able to see myself at night in the vanity mirror. :LOL:
Tactician133
Illinois
Only concern then would be parking outside your garage with the top/freedom panels off and someone being able to access your garage or someone "snagging" your garage door code when your parked somewhere with the top off? That would be a very targeted attack though, guess it would depend on where you live if it mattered to you.
I get it. But for me and many others that never take off the top or panels, it's not a concern.
