Steering Stabilizer Relocation Brackets
CarbonSteel
Hi again, one more question.
Would the kit linked below work for my 2022 JLUR/Fox ATS steering stabilizer relocation, if I add just the Synergy 4051-01 bolt to replace the big gold colored bolt?
Synergy Jeep JL / JLU / JT Steering Stabilizer Relocation Kit for OEM Tie Rod End (polyperformance.com)
Yep -- as long as you get the correct diameter clamp to fit the tie-rod. The one is that kit is for a 1.5" diameter and I thought you were running a MC tie-rod which needs a 1.625" diameter.
JKWMD
Independence Kentucky
2022 JLU Rubicon; 2021 JLU Sahara
No, I have a stock JLUR tie-rod
falcon241073
Trey
Byhalia, MS
2021 JLUR
I "think" the OEM is 1.5", but it has been a minute since I upgraded. If it is, you are good to go.
According to the synergy website the stock is 1.625. The claim the JL/JT clamp they sell is for 1 5/8” tie rod which converts to 1.625”.
Jeep Wrangler JL Steering Stabilizer Relocation Brackets 270CB9A2-CB5D-4E1E-955C-1F60967E9A54
Jeep Wrangler JL Steering Stabilizer Relocation Brackets 608F3978-DD53-42D0-BD13-461FB583DEA6
CarbonSteel
In that case @JKWMD - that is the wrong size and the number you posted is not the correct one.
SDhobbs
San Diego, CA
2020 JLUR
Hey guys any issues running the Metalcloak relocation bracket and a Fox ATS stabilizer JK version, like the pic below? Not my Jeep, it's an image someone posted in the Quadratec site.
Jeep Wrangler JL Steering Stabilizer Relocation Brackets Fox ATS stabilizer
Roky
Roky
I would run MC tie rod clamp with it, the Fox clamp looks like it’s not happy on that angle…. It may be fine, but it bothers me…..
Jeep Wrangler JL Steering Stabilizer Relocation Brackets 62917EFF-E181-4392-A757-737264EA30DD
The MC clamp comes with the stud on an angle …….
Jeep Wrangler JL Steering Stabilizer Relocation Brackets 5E5A3240-B8AB-4723-B744-1E99ACDAE9B3
I personally like to see the stabilizer parallel with the tie rod………..
Jeep Wrangler JL Steering Stabilizer Relocation Brackets C35AFEEB-9394-4729-A81A-D4C5E99C3453
SDhobbs
San Diego, CA
2020 JLUR
What about the Metalcloak Billet mount? It looks like bolt sticks out, won't that interfere with the shock shaft?
Jeep Wrangler JL Steering Stabilizer Relocation Brackets 1650497172192
Jeep Wrangler JL Steering Stabilizer Relocation Brackets 1650497271240
Roky
Roky
Yeah, that bolt would interfere…. Why not use a different axle bracket, synergy bolt , steersmarts, or something that doesn’t raise the stabilizer ? Or are you set on MC ?
I’m using synergy bolt, over 3 years with no issues……
Jeep Wrangler JL Steering Stabilizer Relocation Brackets 22181D78-19E6-4F75-B478-3F644A1BC676
SDhobbs
San Diego, CA
2020 JLUR
The shop that installed my lift and steering stitch welded the Metalcloak relocation bracket for added strength I guess, so i'd like to continue using it but if it won't work I will need to have them take it off and go with the Synergy bolt.
Roky
Roky
Wow…. They didn’t need to do that….anyway, you can use a flat bugle head bolt in place of the bolt in the billet clamp……
Jeep Wrangler JL Steering Stabilizer Relocation Brackets A7B2C557-5B86-4B09-8F44-D67EC3C31DE0
SDhobbs
San Diego, CA
2020 JLUR
I know they went a little overboard, they meant well, in any case that flat bolt could work! Finding one that will fit will be tricky.
Roky
Roky
Holler at @hoag4147 , he might know what you need .
hoag4147
Colleyville, TX
2022 JLUR XR
