Steering Stabilizer Relocation Brackets
CarbonSteel
SDhobbs
San Diego, CA
2020 JLUR
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
That is very kind of you sir! But looking at Metalcloak's specs I don't think that bolt will work, I did find one on Bolt Depot's site I think will do the trick.
https://www.boltdepot.com/Product-Details.aspx?product=15731
Metalcloack specs:
https://images.metalcloak.com/Metal...er-Billet-Mount-Installation-Instructions.pdf
The only concern I would have looking at specs would be length on bolt. MCs version is mounting through normal shock end. The Fox ATS mounting point is not as wide/thick as normal shock end, but I haven't messed with many of these...
SDhobbs
San Diego, CA
2020 JLUR
The only concern I would have looking at specs would be length on bolt. MCs version is mounting through normal shock end. The Fox ATS mounting point is not as wide/thick as normal shock end.
I thought the same so I ordered different length bolts just in case, hopefully one of them fits! I'll be sure to post my findings.
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
CarbonSteel
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Did this ever get resolved? I impulse ordered the Fox ATS before i confirmed fitment with the MC bracket, and now I’m wondering what I need to make it work
SDhobbs
San Diego, CA
2020 JLUR
I had my shop grind off the Metal Cloak bracket they welded on and installed the Synergy bolt. I didn't like the angle of the Metal Cloak bracket, it's too high, the Synergy bolt keep the steering stabilizer level.
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
So… I went with the fox bracket and while it’s far from level, the spherical bearing isn’t fixed and allows for plenty of movement up and down when tightened properly. Does anyone have an example of failure due to the Fox joint? I think I’m gonna roll with it otherwise.
the_cyclist
Serge
Levis
2020 Jeep Wrangler Unlimited Sport
Hi there! I know it's an old thread, but I don't want to start a new one... I am considering the Synergy bracket for my 2022 JLUR. The factory stabilizer has been updated with a bigger bolt on frame (TB) side. Do you know if I will need to drill the 1/2 hole or it should be OK. Thanks guys!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I believe both the stud and the TR side bolt are 1/2", so you'll need to drill out one of the two regardless. I'd use a sharp bit and cutting fluid, I melted the OEM bushing and ended up just replacing it.
the_cyclist
Serge
Levis
Thanks Matt for the advice, I know a steering stabilizer isn't that expensive but I hate to change something when it ain't broke... I think I will have to check those holes, because it has been replace last winter, and the one I have may have return to the old bolt. It appears the one I have now is P/N #68251580AG...
virkdoc
Ramandeep
Chandigarh, India
Cayenne V8, BMW 330i, BMW R1200GSA, Jeep Rubicon 2022
Would any og the relocation brackets work with a RHD JLU also?
