Spare Tire Carrier
MARSHMELLA
Kirt
FL
2021 JLUR
Military
Ok, so does anyone know of a shallower than normal, or adjustable depth, tire carrier? My new wheels are shallower from the rear of the wheel to the back of the holes, so my spare is sitting about an extra 1.5 inches further off the gate than the stock wheels did. Anyone have a fix? Thanks!
As several others have said, the Teraflex Alpha HD covers everything you’re looking for and more.
It also re-mounts your camera in a new housing that attaches via quick connect to the outside of your wheel. Wheel backspace doesn’t matter anymore because it mounts on the outside of wheel.
4xFUN
Scottsdale AZ
Could I trouble you for a couple of pics?
Here are a couple pictures, I had about the same spacing as you before I installed the Teraflex HD Alpha. Another benefit is the Teraflex camera housing is a little longer so you will see more of what is behind you and a bit less of the tire!
Jeep Wrangler JL Spare Tire Carrier IMG_2195
Jeep Wrangler JL Spare Tire Carrier IMG_2192
Jeep Wrangler JL Spare Tire Carrier IMG_2193
aldo98229
Aldo
Bellingham, WA
Market Research
Wish I had known this earlier this week before ordering the Smittybilt relocation bracket.
The relocation bracket arrived before New Year’s. I am now waiting for the tailgate reinforcement; it appears to be MIA... :crying:
rickinAZ
Phoenix
2026 MOAB 392
Aldo, you should just return the Smittybilt. I was in the same position. I ordered/received the Mopar relocation kit before discovering the Teraflex. I just returned it and that was that.
364pipeguy
Paul
Apple Valley Ca.
2019 Rubicon / 1971 CJ-6
retired Steamfitter
When I was using the stock carrier I went with senrgy systems tire bump stops. You can cut them to size and fit where your stock bump stops go.
Paul
WTWTCH
Will
Atlanta
2019 Wrangler Rubicon
Ive got the full smittybilt bracket with new hinges and all. Its alright for the price but it does stick out too far imo. Im going to order the teraflex alpha when the full version with hinges comes out later this year
BamaJeep
Alabama
2020 JLUR Sting Grey
Has teraflex given any indication when the full version might be coming in 2021?
WTWTCH
Will
Atlanta
I called them about a month ago and the guy i talked to guessed they'd be selling around spring this year
Leftwork
Leftwork
Wellington, Fl
2020 Jeep JlU Sahara
I love this forum, Solutions abound. I just installed the TeraFlex alpha HD tire mount and it’s solved 100% of the problems. Perfect solution, thanks again!
1fastss
Mickey
Greeley, CO
2021 Jeep Wrangler
Do your jeep a favor by getting an adjustable carrier. The previously mentioned Teraflex Alpha HD is a great option, if your looking to stick to a 35 or smaller tire. I had one and it was great. Had the inner sidewall pressed into the tailgate rubbers nice and firm. I only replaced it because it was maxed out with a 38x13.5 spare, and I wanted the peace of mind that came with a full hinged tailgate reinforcement with carrier.
I only have rear pics. 1st with a 35 on factory wheels. 2nd with the 38x13.5 on a 17x9 wheel. Both are with the carrier at the highest level.
Did you experience any tailgate sag with the 35" tire? What about rattles?
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
No noticed sag, but my "35's" were the 315/70-17 bfgoodrich ko2's that are on the small and lighter end of what's considered a 35. Some sag and rattles started after I readjusted the Teraflex Alpha HD carrier to properly fit and support the 38's and wheels with less backspace.
1fastss
Mickey
Greeley, CO
2021 Jeep Wrangler
I have 35x12.50x17 K02's. I am on the fence about needing to reinforce the tailgate. Sounds like you were happy with it with the 35's. Is that fair to say?
Headbarcode
LI, New York
The Alpha HD carrier did very well with the 35's. I'd probably still have it if I didn't go larger. It's a great carrier.
Here's a couple pics. 1st was taken down low, which shows how high the 35's sit above the mopar steel bumper with the carrier set to the highest position. 2nd was from a standing position, which shows how much window gets blocked.
Jeep Wrangler JL Spare Tire Carrier 20200423_092815_resized
Jeep Wrangler JL Spare Tire Carrier 20200423_092808
Suffolklou
Lou
Richland Wa
2020 JLUR
Here is the Teraflex Alpha HD carrier with the Rugged Ridge carrier. Lets it be nice and snug. 37x12.5/17 KO2's
Jeep Wrangler JL Spare Tire Carrier IMG_0981
Jeep Wrangler JL Spare Tire Carrier IMG_0967
