Raised Spare Tire Carrier
Paulguy100
Wisconsin
2021 JLU Rubicon
Hoping to extend the stock wheel bumpers to hold the spare more firmly, but it now being raised 4.5" that's not going to work. Any other suggestions to make up about a 3.5" gap between the new carrier plate and the tire?
I'd rather not drill and tap into the plate. Any good DIY ideas?
Roky
Roky
Central Florida
Energy Suspension 29105G Spare Tire Bumper Set https://www.amazon.com/dp/B01IDM1OCE/ref=cm_sw_r_cp_api_glt_fabc_XWHKAJ7FHZV9YNK7C4RV
These say they’re for JK but they work on the JL. They’re about 4.5” IIRC , you cut them to length.
Paulguy100
Paulguy100
Wisconsin
2021 JLU Rubicon
cOtter
Southern, Indiana
‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
Senior Manager PM (Automotive OEM)
Easy fix......
1. Measure the distance from the from the tailgate to the tire surface.
2. Purchase small pvc tube pieces that will fit inside the existing rubber pieces. Make sure to get two pieces of pvc tubing at least at that length.
3. Then buy two rubber stoppers that you would use for the chair leg ends for an old chair.
4. Push the pvc into the existing rubber pieces on your Jeep.
5. Confirm the stack up measurement of the components, trim to length.
6. Place the rubber stoppers onto the pvc.
7. You will need to remove your spare tire after you confirm the offset.
8. After install put your spare back.
This worked for mine. Less than $10.
I know that you have a larger space to contend with but I believe it would still work. If not.... it’s just $10.
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
if you don't want to drill (you don't have to tap the hole) perhaps use a strong rubber cement glue to keep the bumper in place ?
Roky
Roky
Central Florida
This^^^....... If you get the stops I referenced above, you could cut the nub off flush and use some double sided tape or some adhesive that’s paint friendly. I think it’s big enough so you could raise it enough to hit the tire and also cover the hole from factory stop. The pressure from the spare is going to keep it in place so I don’t think it would fall out even if the tape/adhesive failed
more $.02......:)
Paulguy100
Paulguy100
Wisconsin
2021 JLU Rubicon
Easy fix......
Are those 35's? Looks like you have more tire to work with.
CaJLMetalHead
CAJLMetalHead
Dwayne Lane's Chrysler Jeep Dodge
