AnnDee4444
I found that the effective scrub radius of a stock JL Rubicon with 6° of caster (Mopar lift arms) is roughly 1". Since I don't have any actual suspension measurements, I rotated my tires lock to lock a few times before backing up 2'. This leaves a circular imprint on the ground, and finding how offset the center of the circle is to the center of the tire is the scrub radius distance. If anyone has a better measurement, please let me know.
Assuming the OEM scrub radius is 1", the minimum offset is calculated below.
Disclaimer: None of this has been tested, all numbers are theoretical.
For 2" scrub radius (max. recommended for AWD):
The (US) Rubicon should be fine with 3" of scrub radius, since the only time it sees 4WD is off road. Sahara's & other on-road AWD transfer cases should stick to 2" maximum. It is probably best to minimize scrub though, as I suspect it might be a contributor to death wobble.
31.5" tire: 22.6 mm offset
33" tire: 18.6 mm offset
35" tire: 13.2 mm offset
37" tire: 7.8 mm offset
40" tire: -0.3 mm offset
For 3" scrub radius (max. recommended for 2WD):33" tire: 18.6 mm offset
31.5" tire: -2.8 mm offset
33" tire: -6.8 mm offset
35" tire: -12.2 mm offset
37" tire: -17.6 mm offset
40" tire: -25.7 mm offset
