Rubicon Going To 35s
Driftyd
Darin
Michigan
2018 wrangler JL rubicon
I put 35s on my Rubicon and I did not put any kind of lift on it I only put a leveling kit on the front which changed the rake an inch and a half so to make it more level. I also went with the Cooper Discover AT3 xlt because I liked the aggressive tread but I also was doing a lot of highway driving and they come with a 65,000 mile tread life warranty
briggsa
Aaron
Washington
2021 Rubicon Unlimited Diesel
Looking to possibly go with 35s on my Rubicon and would appreciate any and all feedback; pros/cons/which ones to go with/etc.
No lift and keeping factory wheels. 35x11.5 tire.
Probably Toyo or Nitto?
Using the same tires year round with tread comparable to factor Rubicon. Driving is primarily city and highway.
Much appreciated.
Jeep Wrangler JL Rubicon Going To 35s 20201114_165109_2
I got 35’s with the mopar bead lock but they are still 17” wheels. Went with bf Goodrich
Jeep Wrangler JL Rubicon Going To 35s B3B3B563-86C2-4985-ABFD-B5CC6D29A84D
betsy
jeffrey
maine ,usa
2019 jl rubicon 2dr ,2016 jk rubicon hard rock 2dr
I haven’t put them on the jlr 2dr yet, but I had the nitto trail grapplers on my jkr2dr and they were great, fine with the 4.10 gearing, I currently just installed the nittos on my gladiator, really improved the ride and handling. The only thing with the jkr was 2 1/2”lift and AEV wheels which I will probably do on the jlr and a leveling kit.
deaHelkcunK
Naples, FL
1965 K1000 Suburban, !968 Chevelle SS LS9, 2019 X7, 2020 JLURD, 2021 Silverado
Much appreciated.
Jeep Wrangler JL Rubicon Going To 35s 9E03FC36-08B8-48FA-9F61-D289952DEC45
That was originally my intent too on my 2020 JLURD. The factory wheel width was too narrow per BFG specs so I ended up doing wheels too. No lift, no rub, slightly harsher ride (but my tire pressure is 45psi, still adjusting it down. I put the KO3's on mine.
betsy
jeffrey
maine ,usa
45 lbs. is too high start around 34 lbs ,may have to go up or down a couple lbs.
AppleJacks23
A.J.
Rockwall, TX
www.revkit.com
2021 JLURD
Human Resources
315/17/70 bfg ko2s on stock Rubicon wheels with no lift (yet) on 21 JLURD. Load range e. No concern with tire width as it fit specs and no rubbing even flexed. Have aired down and run off road (rocks etc) no issues. Good on highway too and in snow. Want the lift for extra breakover clearance.
betsy
jeffrey
maine ,usa
@Jeepster21 - here is a comparison sheet I created that may help. There are multiple tabs sorted by different attributes:
What happened to the nitto 35x11.50r17 c- rated, all of the 315s are actually too wide for the factory 7.5” wide wheel, although some of the tire outlets say they are, because most of them are actually 35x12.50r17.
CarbonSteel
2023 Ford Bronco Wildtrak
Not sure, I collected as many different 35" tires that I could and put them on the sheet. When I look at Nitto's site there are no 315/70/17 in Load Range C, only Load Range D or E.
I am running Kanati Trail Hogs 315/70/17 on OEM wheels with no issues. I like the slightly tighter grip on the bead when I air them down
DanN427
Long Island, NY
2021 Firecracker Red Wrangler Rubicon 4Xe
It's New Tire Tuesday!!
Just finished putting on 315/70/R17's on stock Rubicon wheels with no lift kit:
Before:
Jeep Wrangler JL Rubicon Going To 35s 20210622_080540
Halfway done f/ comparison:
Jeep Wrangler JL Rubicon Going To 35s 20210622_094928
After: (sorry, started raining and didn't have a chance to clean them):
Jeep Wrangler JL Rubicon Going To 35s 20210622_130246
I love the way it fills the wheel wells a bit more!
Can't wait to clean it up and take it for a test drive!!!
arronlol
Aaron
Seattle, WA
Jeep Wrangler Rubicon
