Rear Cargo Dome Light
JLUW83
Wisconsin
Jeep Wrangler Willys
So I got tired of having very minimal light in the cargo area of my JLU Willys and added this UTV dome light to the rear glass. Mounted it to the wiper cover and ran a 12v wire to the 12v power outlet in the rear. Very clean mod. Something Jeep should definitely do in the future! Plus the dome light has a red and white light option.
Jeep Wrangler JL Rear Cargo Dome Light FF627C6A-7B09-4874-8858-F0C9CFC560A6
Jeep Wrangler JL Rear Cargo Dome Light 422C9B47-0978-45B3-8BD9-698307A65F4E
Jeep Wrangler JL Rear Cargo Dome Light 86999A03-5ED9-4001-A735-0BCF2ED3122F
JLeco2022
Anaheim, CA
2022 Wrangler 3.0 V6 Eco Diesel
did the same thing for overhead lighting for driver/pass and rear cargo area, wired some white and red led's to switches and some relays, cost like 12 bucks and a 3d printer
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
this is absolutely awesome , nice compact design, and has on/off switch built in! Thank you !
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
This works well, also, and sticks anywhere. ?
Jeep Wrangler JL Rear Cargo Dome Light 1701726283082
Ormond Beach, Florida
Retired at 55 ..
Nice! Been looking for a solution like this
@skylinechaser16
In the 2018 JL's and into the model year 2019, the interior dome light is not bright enough / is very bad in regard to white light output.
Fortunately, the chitty dome light on your 2018 JL, can be easily replaced and the difference in the interior light up when the dome is lighted, is outstanding.
Read here:
https://www.jlwranglerforums.com/forum/threads/cheap-jeep-hacks-show-em-off-here.18785/post-2523234
All K ratings of the LEDs appear identical - Center oval, LED is ~6K (WHITE) and so are the 4 side Led's on the revision.
Jeep Wrangler JL Rear Cargo Dome Light 20231115_161725
Kleiss1
Gary
Arizona
2021 JLURD 2018 Mustang GT 6-sp.
Is there a link for this light please?
Kleiss1
Gary
Arizona
How did you hide the wires? How do you access the outlet back there? Thanks
JLUW83
JLUW83
Wisconsin
There is a wire channel that runs from the wiper housing to the topside of lift glass then the wires run through a wire loom into the hard top. Run your 12v wire through that route to where your wire connectors are inside the jeep. I used a deutsch connector to somewhat match the factory connectors. Then ran the 12v wire to the 12v outlet and spliced it into the power wire. Back to the wiper motor housing, I grounded the dome light to a metal plate on the wiper motor. Here are some pictures.
Jeep Wrangler JL Rear Cargo Dome Light 62F25F99-8729-4C67-BDB2-46D24366CB69
Jeep Wrangler JL Rear Cargo Dome Light 1D7E62B3-4DB2-4221-8A00-5F4FECE9938B
Jeep Wrangler JL Rear Cargo Dome Light D40B06D1-BD7A-4191-99BA-38BE56A970F9
Jeep Wrangler JL Rear Cargo Dome Light E7441437-61DF-424F-AAA5-CF14B45DBA73
Jeep Wrangler JL Rear Cargo Dome Light AFA01261-0890-476F-A6F3-97807D64212E
Kleiss1
Gary
Arizona
If anyone is interested this is where the clips are to remove the cover.
Jeep Wrangler JL Rear Cargo Dome Light IMG_7453
