Phone Holder Alternatives?
Terminex
Omaha
2021 JLUR 4XE
Fixing stupid....
Thank you. That looks exactly like what I want (i.e. no arm), can you confirm what ball size the phone charger is? I just want to make sure I get the right vent clip (17, 20 or 25.4 mm). TYIA.
17mm
Ghost7th
Ghost7th
Pat
Central Pennsylvania
2020 Sahara
Thank you all for the replies!
I decided on the ProClip Center Dash Mount with the Adjustable Holder for Small to Medium Cases. I am hoping to receive it by the end of the week or early next week. I'll follow up once it's installed and I use it for awhile.
I liked that it could be moved over a larger area of the dash and that it is easily removed if I temporarily don't want it in there for some reason.
OHJeeper
Austin
Ohio
2008 JLUS, 2008 JLUX, 2018 JLUR
Anyone have an issue with the 67d and the universal phone mount where you go to put your phone in the mount and the arm moves? I have it cranked down as hard as I can and it will still move side to side when I try and put my phone in.
I have the same issue with mine. I think it's just the nature of a ball-mount + friction. Once it moves a little (like, before I tightened the ? out of it) I think it creates a groove in the ball that just continues to get bigger/looser as time goes on... Mine only moves a cm or two, does your's move more?
Whaler27
Alex
Oregon
Saving the world :-)
I have the BulletPoint system in my Raptor and the 67 Designs set up in the Wrangler. Both are expensive, very well built, and very stable.
If I had it to do it all over again I'd go with BulletPoint in the Jeep too, as I found their bundling and pricing more understandable, sensible, and affordable.
CJ7 and 4 wheel drive
Gary
2020 Wrangler Rubicon
Hello all:
So far the only thing that has disappointed me about my Jeep is the lack of a valid place to keep my phone. I have been using the little cubby hole below the media ports but it is a pain in the ass to get the phone out of some times and with it out of sight I end up forgetting it and having to go back and retrieve my phone once I realize it. I have decided that I need some auxiliary switches so that storage option should be going away soon.
I have spent a few days reading reviews and posts on phone holders and I am still not sure what I need. I was sold on the Bulletpoint ones until I saw a few videos with people complaining about the clamps not staying tight and the rods moving and also that there were some quality control issues with the mounting plates that would make them not fit correctly.
I will never do any rock crawling or crazy speed washboard roads so I don't need an extreme model. I am looking for something affordable that will mount easily (I love how the Bulletpoint one mounts) and will securely hold my phone where I can easily access it if needed.
Any feedback would be greatly appreciated.
Search for Panavise. 2
1leftygolfer
SW Florida
2021 JLURD Nacho
For what it's worth - I've had success scuff sanding (don't remember grit #) the ball. Not a lot, just enough to add grit for better clamping.
Go4Low
Jorel
2020 JLUR
I got rid of all my clips for magnetic Holder. Works well with Radio
SCOSCHE MPD2PK-UB MagicMount Pro Universal Magnetic Mount Holder for Vehicles, Black (Pack of 2) https://www.amazon.com/dp/B079W8QKP...abc_4QDE713W068KF7DM3ZME?_encoding=UTF8&psc=1
Hello all:
I got rid of all my clips for magnetic Holder. Works well for my Radio mic aswell.
wolf
florida
On my third Rubicon(2dr's 2020, 2015 jetta diesel/2013 mb
retired
If you upgrade to the iPad Mini Mega Micro Max Ultra you could completely block out that pesky windshield view...:giggle:
Most states will give you a vision obstruction ticket for that view. Be careful.
MandrewSD
Andrew
San Diego
JLUR 392
That is not my Jeep, I was replying in a funny way and even made fun of the obstructed view. If you are truly concerned you should reply to the correct person.
galleywinter
Tod
Fayetteville, Arkansas
2015 Hard Rock JKU, 2018 JL Rubi, 2020 Mercedes GLC 300(Wife) :-)
Environmental Manager, VA Hospital
Ordering parts now for soon to be delivered Rubi XR. I've decided on 67 design but..... I want to keep my mag safe charging. 67 has lots of options but their mag safe doesn't charge. Yes, I can just plug in my USB apple cord into my phone but that's not what I'm after. Not even concerned with still having wires. It's called mag safe cordless charging but there's still a cord :) I'll have to plug a wire into the mag safe charger anyway. I might at some point go thru the hassle of trying to hide the wire or do what some have done and tap into the cig lighter hot and neg but for now just wanting to mount 67 but still be able mag safe charge.
A lot of the mag safe chargers on amazon have the ball mount but they are 17mm mounts. 67 uses 20mm mounts. They do make a 17 to 20mm converter but trying to avoid that.
Anybody out their using 67 Designs and still mag safe charging?
Thanks
Ghost7th
Ghost7th
Pat
2020 Sahara
My ProClip came yesterday. It took me longer to find a Phillips head screwdriver to fit the little screws on the mount than it did to do the actual install. I like the fact that I can change the location on the dash as needed.
Pros - Easy/quick install, good quality, holds phone secure, looks good, allows me to still put stuff in my dash junk bin, I know where my phone is now.
Cons - none so far.
**oh, I think it's rained every damned day since I bought my girl. I had one day that I could drive with the freedom tops off and not worry about getting rained on (WTF).
Jeep Wrangler JL Phone Holder Alternatives? phone 1
Jeep Wrangler JL Phone Holder Alternatives? phone 2
Jeep Wrangler JL Phone Holder Alternatives? phone 3
Av8Chuck
Chuck
Thousand Oaks, California
2020 Rubicon
A couple of installation questions. Do you think it would damage or change the flex of the ProClip if you drilled a whole in the "arm" to install a GoPro type mount?
If you mount a cell phone, tablet and camera, for example, how do you power them? I'd rather not run the USB connectors up the front of the dash but I don't want to totally dismantle the dash to run the wires. Is there a way to fish them from behind the dash?
It might be nice to be able to use Apple CardPlay as well.
schwizzie
Noah
Germany
2018 JLR
I ran a usb cable from the center console, under the hand brake area and up behind the dash. It took about a hour. The hardest part was unbolting the center console in the back to drill the hole and fish the wire through the center console.
Jeep Wrangler JL Phone Holder Alternatives? E897E127-626C-410D-94F0-D5B917011F0B
I removed the rubber liner in the bottom and drilled the hole in the rear drivers side corner.
Jeep Wrangler JL Phone Holder Alternatives? B2DCB7AC-A889-4244-B8AA-DA6AE5683170
You only have to removed the AC control module (takes less than a minute), and unbolt the radio. You can fish the wires up from the bottom and easily access the top tray.
Jeep Wrangler JL Phone Holder Alternatives? 38DFD22B-76CA-4B3E-9B51-FADE406CE85D
BATIGE Square Single Port USB 3.0... https://www.amazon.com/dp/B07CKM7KGK?ref=ppx_pop_mob_ap_share
This is the usb cord I used. I installed it back in July of 2020 and it has worked flawlessly.
Jeep Wrangler JL Phone Holder Alternatives? 6A9AE9B6-66A6-4EF7-8D8D-BFB7C84465FC
Finished product. I couldn’t be happier with it.
OffroadCalling77
Josiah
Brea, CA
21 Rubicon 392, 21 Sahara Altitude
Biz Owner
This is exactly what I’m looking to accomplish. I would like to have possibly up to three chargers but I would be satisfied with two. Is this enough to charge an iPad Pro over that distance?
WOwen
William
Chicago
2018 WB Hellcat, 2016 Wrangler, 2021 392 Wrangler
I have the Bulletpoint Driver and Passenger side mounts. Use Passenger side mount 80% of time unless the kid uses it. Driver side is great for sideways using maps.
