Oil Change Torque Specs
Valpo Jeep
Doug
Valparaiso IN
Been changing oil on my own vehicles for 40 years. Never once used a torque wrench during the process.
Everything has an engineered torque value even the bolts for your license plate but somethings you really don’t have to torque
Tr4ckD4ys
NY
2025 Jeep Wrangler Rubicon Xtreme 35-inch 2-door, '41 Green
Tech
But you have to take into account your wrist torque declines with age.
😂 In my case that only means I’ve been overtorquing my whole life and am slowly getting closer to an acceptable level!
  • Like
Reactions: LAM
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
I used a silver Sharpie marker and drew a nice line down the front of the oil filter housing, then removed it and changed filters. Carefully screwed it back in until the silver line was forward and I felt it bottom in the threads...not one millimeter tighter! LOL
I re-used the oil pan drain plug, it's got some kinda co-moulded rubber gasket on it (or so it appears), tightened snug but not overly so with a box wrench.
flyer92
Nevada
What is this rubber gasket on the drain plug? My '21 never had that, and I haven't seen it on any '18 thru '22. Was this added in later models perhaps?
Pismo61
Temecula,Ca
2026 JLURX
Yep,all you need to do.
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
I don’t think the 30 ft/lbs is correct. ALLDATA says 20 ft/lbs for my 2025 Rubicon X VIN #.
If you’re talking about the drain plug, that’s correct. 3.6 oil filter cap is 18.
WillysMeow
Corruptifornia
Bit wrassler
Dunno, it was first oil change and it almost looked co-moulded onto the drain plug which is a steel bolt with flange around the head...never seen one with gasket looking dealio like that...wiped clean and re-used, knock on wood no drips lol.
flyer92
Nevada
Interestingly, the fac
OK...I have seen that on several other vehicles in the past, but never on a JL. Maybe it is a replacement bolt? Did you buy your Jeep new?
That type of seal is OEM on GM LS/LT engines. I liked it so much, when I welded a bung on the GM truck transmission pan, I used the GM engine drain plug.
Terrymo
Terry
2023 JLURXR 3.6 ET
My 23 3.6 OEM drain plug bolt has the rubber overmolded flange. This is a pic of some Crown Automotive spares ( I’m a hardware hoarder) but my OEM looks the same, just a lot dirtier.
Jeep Wrangler JL Oil Change Torque Specs IMG_1728
WillysMeow
Corruptifornia
Bit wrassler
Interesting, similar but different, thanks for the picture.
