Off road plus????
Jtphoto
Thunder Bay ON
Let me change that. Not very bright to drive in 4x4. Thought common sense would take over. You can do it but pretty dumb too.
Driving on dry pavement or highways with a 4x4 vehicle (especially while the center diff-lock is switched on) is always a bad idea. You should aim to never take your 4x4 out on the dry pavement, as four-wheel drive simply isn't suited to such a surface, and this can increase the risk and danger while you're on the road.
You can run 4X Auto in any condition. It is an “all wheel drive mode” designed to be run in bad weather.
Bhodi11
Chad
Raleigh, NC
392XR
In a 392 off-road + is like sport mode. It can be used in 4auto on dry pavement in addition to 4H off-road.
Jtphoto
Thunder Bay ON
It's more of a "4x4 on demand" than an "AWD mode". There is a marked difference between the 2.
There is as much difference in AWD between manufacturers as there is here. Either or, it is close enough for this discussion.
Rusty Shovel
Rusty
2002 TJ, 2005 TJ Rubi, 2012 JK Rubi, 2023 JLU Rubi
Try 4Hi, off-road +, then turn on the rear locker. Drive a bit and switch to 2Hi see if the locker stays on.
my new Rubi hasn’t come in yet so I can’t try it.
Wait, you can lock the rear in 4 hi when off road + is engaged?
my 2023 is in order, but my JK would only allow locking in 4lo.
Remorseless
NC
Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Not Only The Guy Who Defines What A Jeep Guy Is, But Also The Guy Who Defines What A Jeep Thing Is, Guy Who Has The Authority To Do That
Yep, 4H can lock rear and disengage Rubicon swaybar with off road + set (up to 18MPH for swaybar, not messed with the locker yet in 4H personally). And in 4L, with off road +, you start in 1st in the auto vs 2nd without off road +. There's other traction control things and whatnot engaged in both 4H and 4L with off road + turned on.
AZJeepGuy
Ron
Arizona
2022 JLUR Hydro Blue
So when I ordered I knew what I was getting into with lockers, sway bar disconnect, and the 4wd I chose. But what on earth is this off road plus button?
Activates the driver's side butt pucker massager.
Wrangler man
Howard
Palm Springs
2020 JLUAD
Off Road + was developed for the Mojave Gladiator, which is geared towards high speed off-road driving. FCA/Jeep thought it it would be a good idea to add it to various JL models as well.
?correct answer!
Jtphoto
Thunder Bay ON
And now it will also be on the Willys for 2024.
epd313
rob
erie pa
2023 JLURXR, 2019 Genesis G90
It's for when you want to turn it up to 11
Loved this is spinal tap! My wife doesn't get the humor and thinks it's stupid... It's a classic! Nice reference
JINO
Jino
Socal
2021 jlurd
I pushed the offroad + button today. All I noticed is that it opened the offroad pages app on my stereo.
Didn't really notice any mechanical difference.
Snowboardinwny
Buffalo NY
2014 528i
Do you have 4H auto? If I have it in 4H auto I notice my shift points are higher, shifts are quicker, and throttle response seems to be more responsive. That's on the road.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Th
That's very odd. Being in 4 auto shouldn't do any of that, it should be the same over both 4wd modes. In saying that, who knows with all the electronic crap we have. I don't think I've ever tried Off Road + in 4Auto either as a matter of fact.
Snowboardinwny
Buffalo NY
2014 528i
Th
I believe it does, however I can only speak clearly on 4H auto. I do use off road + while offroading in 4L but with the low gearing I don't think it is as noticeable.
Also, when it 4H auto when coming to a stop engine braking is more noticable.
ChuckQue
Charles
www.stayreadyoutdoors.com
2022 JLURD
Owner of Stay Ready Outdoors
My eight year old calls it the “Fun Button”. He thought it was a hoot when we were tearing ass through the desert washes.
