Noob with JScan....tips?
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Has anyone disabled TPMS and if so do you get any annoying messages or sounds on startup ?
I have mine disabled. No messages or sounds. I think that part of the screen actually disappears if I remember right.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
I know when I ran a Tazer several years ago when I disabled TPMS the screen disappeared and thats ok and I got no error messages but did get this annoying “Ding” sound right after startup.
I have already downloaded the app and have been looking thru the demo mode and it seems to have a ton of things you can do with it
mushroomax
Max
2020 JLUR
Good question! I haven't tried using the app yet without data service. It would be relatively easy to test. Just put your phone in "airplane mode" and see if you can still scan for codes.
I don't have any JScan products, trying to figure this out before purchasing
Redneck_Jedi
Currently Roaming
2019 Jeep Wrangler Sport S 2 Dr.
Found it. So I guess that will disable the hologen setting automatically.
"LED Front Fog Lamps Present On/Off"
There's also an option to allow the fog Llghts to stay on when the high beams are active.
Multiple places..
Here's two goodies, not all JSCAN user's may know is doable with JSCAN:
Disables Weather Alerts.. Do know it also disables Travel Link:
ADAPTATION ---> Radio user settings --> SDAR Travel Link Feature Present On/Off--> Target Value = Deactivated
Fogs with High Beams:
ADAPTATION --> Vehicle user settings -> Front Fog Lamp Dropout Enable On/Off --> Target Value = Deactivated
cride1
2018 Jeep Wrangler JLU Rubicon
So is it true that if you disable the auto start/stop feature that you also disable remote start?
Stuckinthesand
CJ
NJ
You can’t disable start stop with JScan. I think you can with the tazer but I haven’t heard anyone say that remote start is also disabled.
cride1
I believe it can be done, but you also have to remove a switch under the hood for it to actually work. When you go into that menu on Jscan, you deactivate it, then it gives you the other steps to finish the deactivation. I decided not to do it, but forgot to change it back before unplugging it. Now it just gives me a single honk and doesn't start.
Stuckinthesand
CJ
NJ
That I didn’t know. Last I heard they were still working on it. I’m assuming it is one of the hood plungers. If that’s the case I could see why it won’t remote start as it thinks the hood is open.
cride1
It is one of the plungers. I would be surprised if there are that many folks that hate the auto start stop so much that they would give up remote start. I have perfected stopping with just enough pressure to stop without killing the engine anyways.
Stuckinthesand
CJ
NJ
That’s a weird one first I’ve heard of it. Personally I’m so used to hitting the start button then the start/stop button. Every once in awhile I do forget and I stop and I go “damn it”.
AllenTC2
AllenTC2
Allen
Cross Lanes, WV
2020 Wrangler Sport S in Granite Metallic
Same here, though with harsher language.
Yellowssm
Ray
Las vegas
JLUR
Is there a way to enable sway bar disconnect in 2wd, or over 18mph yet?
Also is there a dedicated JScan page on this forum to ask questions and what not?
