mopar lift question
e-verland
Tennessee
2023 Jeep Wrangler 4xe
High enough that someone needs a rope to climb in it!
What tube doors are you running?
Yeah, that was for the kids. :)
These are mopar tube dors, not cheap but I think they look really good. And they are made of beefy steel tubes
AC77
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Here is my before and after with the RK pads and Mopar lift. This was years ago and now maybe the springs are improved and the RK pads add too much??
Hi. Going through the replies. I meant to ask. Is your JL diesel also ? What is the part number of the right front /passenger front spring ? I see blue tag I sure the driver side has a difference color. Just want to compare to mine. Does the right side end in 666aa or 667aa ? Thank you
AC77
AC77
AC Abegian
Los Angeles
Just throwing something out there, I don't know where the new instructions are.
The Mopar lower you posted says right, and the p/n matches the old right p/n.
The Mopar instructions show the coil termination positioned to the rear. Your picture shows it positioned to the front, 180 degrees off? Or is it upside down and I'm being dumb?
I’m going through all the replies to make sure I didn’t miss any info. But which photo ? Which side ? Which one is wrong please !???
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I was talking about the picture you took of the Mopar lower isolator outside the jeep compared to the instruction illustration. This was when I thought right meant passenger, though.
Who f'n knows whats right with how screwed up those instructions are.
AC77
AC77
AC Abegian
Los Angeles
if you are referring to the large and small isolators off the truck, those are the old one's
kah.mun.rah
Merenkahre Jr.
Duat
This was on my 2018 JLUR 3.6L. I don't have the Jeep anymore to check the part number in person but here is a closer look of the tag in the photo. Looks like it ends in 067AA. Yes, I think the tag on the other side was red.
Jeep Wrangler JL mopar lift question 1708714720985
EDIT:
The spring on the other side is a red tag, part number 065AA.
Jeep Wrangler JL mopar lift question 1708715218253
These are the part numbers from the install instructions back in 2018-2019ish. Not sure if the numbers are the same today:
Jeep Wrangler JL mopar lift question 1708715498595
AC77
AC77
AC Abegian
Los Angeles
EDIT:
copy that, thank you Sir !
AC77
AC77
AC Abegian
Los Angeles
Wait, WTF.
The next page shows part N as Driver and Part M as Passenger. Both coil terminations forward.
this is what im realizing , how messed up the directions are, both coils terminates are facing forward, but it can not be if there is a left and right isolators, as the flat ends of the isolators have to face out, toward the wheel, so either they need to be reversed AND crossover the coils... i will find out tomorrow , as i will be removing it all again ... where is my 2 liter bottle of Vodka ?
AC77
AC77
AC Abegian
Los Angeles
do you have a photo of your driver side spring and where the coil terminates please ?
going over the mopar manual, it shows both coils terminate to the front of the car, not one to the back and one to the front....
UGA Wrangler
Ben
South Carolina
2023 Wrangler Sport S
Hello, anyone who has installed their Mopar lift kit, did you also replace the rear track bar ?
I just had the Mopar lift installed on my 23 two door and I am not going to do anything additional with either track bar. My rear axle is essentially dead on center and my front is less than an half inch off after the lift. It drives perfect. The updated Mopar lift is much better than it was previously. The spring issue is no more.
AC77
AC77
AC Abegian
Los Angeles
About to remove it all and re Inspect. Photos of right side. Passenger spring and Mopar provided pad.
Jeep Wrangler JL mopar lift question image
kah.mun.rah
Merenkahre Jr.
Duat
Unfortunately, I don't think I do. That Jeep was totaled in 2021. On my current Jeep I went the TeraFlex lift.
