mopar lift question
AC77
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Did you happen to take a picture of the P/Ns of the upper isolators? Should be able to prove it out that way pretty quick.
i will, haven't done that yet . the RK video posted above , showing to cut the 2 rubber nipples and rotate then ( top ones) but then should i install the RK lower pads like before or the Mopar ones from the lift kit ?
zouch
Berkeley, CA
XJ, JLUWD
to your original question:
yes, i put adjustable front and rear Track Bars in after i put the Mopar (Fox) lift under my EcoDiesel Willys because i needed to get the axles squarely back under the vehicle. FWIW, the lift took my Willys up over 4" at the front axle, and almost 3" at the rear axle. the front came back down about 1" after adding a winch and matching bumper.
i put a Rear Track Bar Relocation bracket in later to correct the Roll Center (which helped get rid of the 'wiggle'), and because of it ended up adjusting the track Bar back to where it was about stock length. were i to do it again, i think i'd try adding the Relocation Bracket to see if that put everything back where it belonged before doing a rear Track Bar.
to your later issue;
here are some pics of the front springs with the Mopar pads for your reference. there's a little bit of outward spring bow, but this is after 35K miles/3years, and nothing seems to be making any untoward contact.
Hello, anyone who has installed their Mopar lift kit, did you also replace the rear track bar ?
AC77
AC77
AC Abegian
Los Angeles
Did you cut the upper pads the little locating nubs and rotate them ? There is an RK video link one of the gentlemen posted on this convo. Can you please show your from track bar a close up of how far you have set the adjusting head maybe with a tape measure or a caliper ? Also during the install did you notice the factory left spring of was small and passenger side larger with a step up ?
Jeep Wrangler JL mopar lift question IMG_2775
zouch
Berkeley, CA
XJ, JLUWD
i didn't use RK stuff, so comparos of the adjustment wouldn't necessarily be relevant.
not sure what you meant by "...spring of...", but i don't recall this many years later the differences of anything from side to side; just followed the instructions at the time (which were known to have errors; later revisions were revised to swap spring numbers, for example).
AC77
AC77
AC Abegian
Los Angeles
Auto correction- spring pad
AC77
AC77
AC Abegian
Los Angeles
thanks for the photos , looking at the left side spring , im assuming the coil terminates toward the back ?
AC77
AC77
AC Abegian
Los Angeles
AC77
AC77
AC Abegian
Los Angeles
did you install the lift yourself ? could any of this have to do with being on a driveway at a slope and lifted the front ? i mean its not rocket science , im going to check the upper spring pads, i think they have left and a right , and according to RK, cut the 2 nubs and rotate them , i think it may straighten the spring from up top and a bit away from touching the frame rail
AC77
AC77
AC Abegian
Los Angeles
Yeti also makes a nice adjustable HD front track bar.
I've installed front and rear's JKS , i really want to see what's everyone's adjustment on their front track bar ... just as a baseline.... with a 2" lift
AC77
AC77
AC Abegian
Los Angeles
also , can anyone confirm based off the part numbers if the front spring part numbers are as follows :
68488667AA RF ( according to the manual )
68488666AA LF ( according to the manual )
maybe these are reversed for the Diesels ?
Willys_Wonka
PA
JLUW
Mine was professionally installed, sorry I can’t help ya out with measurements.
Roky
Roky
Front track bar 34-3/16 center to center of connecting bolts…..37-9/16 rear track bar….. these will get you very close, depending on how much lift you get might need fine tuning, but these measurements will get your axle centered enough that it won’t be the cause of your spring bow…..
AC77
AC77
AC Abegian
Los Angeles
thank you !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
dayusmc
Jersey Shore
2020 JL
What is the wiggle you are talking about (I am new to JLU)? I bought an adjustable rear track bar for my wife's High-Tide that I haven't put in yet. But I always wondered what would be the difference in the adjustable rear track bar and the relocation bracket.
