Locker Position Sensor Potting - DANA 44
CenTX JPR
Central TX
2018 JLUR, 05 TJR 6spd
(I *was* getting an intermittent locker error for a while last year, but it turned out to be nothing more than dirty wheels.)
How do you get an error for dirty wheels? Anyone else get this? My wheels are often dirty, no errors. Maybe I'm not getting them dirty enough?
OldGuyNewJeep
Don
CT
roaniecowpony
Retired Engineer
The front wheel sensors are fully inside the unitized hub and no debris can get in there, if the hub is healthy. The rear sensors are inside the brake drum/backing plate and can get dirty from submersion in mud/water and possibly just dust. But they are Hall Effect sensors and are very tolerant of debris, unless its magnetic.
OldGuyNewJeep
Don
CT
?‍♂ Beats me. All I know is a 900 mile round-trip that included light off-roading and some deep puddles fixed it. That was back in September and problem has never returned.
swampflyer
rick
florida
retired
How do you determine which sensor is the right one. Thinking about setting up aand potting a reserve to have on hand. There has to be a way to check for the right one. I can’t see installing and removing until the right one is found. Had my rear one replaced under warranty by dealer last year or so ago and it was replaced pretty quick. Like one hour.
roaniecowpony
Retired Engineer
I just bought a z auto jumper harness for $180. Unless there's a downside, I doubt I'll replace the sensor.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
That is literally how you check to find the ones you need.
  • Like
Reactions: eck
HungryHound
Rick
TN & FL
1975 CJ-5, 1983 CJ-5, 1998 TJ, 2021 JLURe
I've gotten the "service 4wd system" error twice now from dirty wheel sensors. A 4wd vehicle should have a transmission output sensor instead of relying on ABS sensors to determine slippage. Just Jeep being Cheap.
swampflyer
rick
florida
retired
I understand that. I’m just saying there has to be a better way. Since everything else is keyed to your vin maybe. Just saying. I’m sure there is someone with a better idea. Anyway thanks for the reply.
Dyolfknip74
2021 JLU Rubicon
Nah, it's the nature of the connector and the fact that gears aren't that precise. I think. I ended up having to get them and of the 5, only 3 worked. Sorry if I came off as a dick. Lol.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Every manufacturer has gone that direction.
HungryHound
Rick
TN & FL
Yep. And we have high fructose corn syrup instead of cane sugar. Doesn't make it right; doesn't make me like it. Somebody needs to put the bean counters in their place and focus on customer desire over profit.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Let me know how that works out for you.
CharlieVictor
Mini Cooper, 4XE, Tacoma
Thanks to this write up, I got this done on my 2023 4xe last weekend at 10K miles. I was surprised at how dirty the front diff fluid was; from reading here I expected the front to be cleaner than the rear, but they were about equally dirty on mine. Both axles had stuff accumulated on the little magnets as well, but the sensors themselves were still dry. One disappointing discovery was that the axle drain plugs have been removed from both axles now. Thanks to the OP for putting this together!
HungryHound
Rick
TN & FL
Interesting. Are you running in 4-hi-auto regularly? My front was much cleaner when I did mine, but I hadn't done much off-road driving before opening it up.
