Let's talk coffee, what is your set up?
Avar928
Michael
DMV
2026 JLU 3.6 Willy Anvil
I use a Moka Pot on my Jet Boiler with the pan adapter. Any recommendations on a portable grinder for taking camping/hikes? Looking at saving on size and weight.
dustdriver
E. Oregon
www.jlwranglerforums.com
2018 Unlimited Rubicon
Melitta No. 2 cone!
Makes a superb cup of coffee. Filters readily available. Super quick and easy, doesn't need water to clean up afterward (handy on desert trips), and doesn't require any special gadgets or anything- just boil water and you are good to go.
Jeep Wrangler JL Let's talk coffee, what is your set up? melitta_No2con
InvertedLogic
Denver, CO
20 JTR
I just use a stainless steel double walled french press. Simple, durable, and excellent coffee. The glass one I used to use broke in the mess box. Grind the coffee before I leave then use a 1 heaping spoonfull / cup.
Jeep Wrangler JL Let's talk coffee, what is your set up? 1594155326638
Punkn18
Ryan
Missouri
2018.5 JL
We have a 2020 NOBO 10.6 off road. We bought a plain Jane percolator from Walmart. The cheapest we could find. If you don’t overfill the water line and keep the coffee light it won’t get the grounds into the good stuff. Sorry no
Pictures as it’s packed away in the camper. The plan was to use it over the fire but that propane stovetop fits the bill just fine
Punkn18
Ryan
Missouri
2018.5 JL
Jeep Wrangler JL Let's talk coffee, what is your set up? 339F6416-8B8F-4D53-854D-9119703A9DEE
F800
Canada
2020 JLU
My no fuss, on the road / coronavirus avoiding people coffee set up is Starbucks singles with some milk in the cooler.
Amaruq
Atlanta
JLR 6spd
Rather than starting a new thread...
Do any of you recommend a single burner for boiling water? Not a lot of water, maybe a quart at a time (definitely under ten minutes!).
Does anyone use an electric one?
bigbaozi
Wrangler Unlimited Sport S
If you just want to boil water, get a Jetboil or similar. Walmart even makes one now. They are super fast and use those little backpacking fuel canisters.
flyingyogi
yogi
2020 jeep sahara ecodiesel
I use this for boiling water, works well and does double duty for usb charging.
Jeep Wrangler JL Let's talk coffee, what is your set up? CampStove2_1_larg
JimLee
Jim
Too damn close to Death Valley
'19 JLU
Anyone seen anything made for outdoors that uses a pod and can be powered from 12v? I don't need anything fancy, i personally hate coffee but I need caffeine and am allergic to energy drinks.
Amaruq
Atlanta
JLR 6spd
I used to swear by the French press method... until I discovered Aeropress. Leaps and bounds better in taste and cleanup. Consistent results.
By the way, ordered the Jetboil Flash. Thanks for the rec!
Jetboil, Javapresse manual grinder, Aeropress. And an Aeroccino. I’m all set.
Fuzzy Dave
NV
2019 Unlimited Rubicon
New camping setup test, Black Rifle instant sticks are good! Way better than the Starbucks Via in both taste and texture. They fully dissolve compared to the Via which was always a bit gritty to me.
Jetboil Flash had the water boiling in the time it took me to open the coffee box, way better than an open pot on the old Coleman stove!
cannot recommend this enough. .it is super efficient and im using a med size fuel canister and it has lasted multiple trips so far. ..boils water even at elevation in mere minutes. ..by far the best one i have used.....
i also bought the french press adapter for the large can and it makes enough for 2 travel mugs.
Amaruq
Atlanta
JLR 6spd
This may already be known, but the Jetboil fuel cans are only $5-6 at REI stores compared to $20 at Amazon. Thing I learned today.
