Latest TSB on the Pentastar engine
Jtphoto
Thunder Bay ON
Why do you think there is a nationwide backorder on the cams? my Jl is sitting right now waiting on a intake cam. I have babied the crap out of this vehicle. 40K miles in 7 years. Oil changes every 5K is just the start of the maintenance i have put into this money pit.
Parts supply issues. New vehicle production takes priority… Just because it’s hard to get parts doesn’t mean they can’t keep up with repairs. My son had to wait 3 weeks just for a heater hose for his RAM. Does that mean all the hoses are bad? Same for a rear shock, 1 month wait for that.
tshep
Tim
Pomona, Ca
2018 JLUR / 2000 F530 7.3
Heater hose, Get the f' out. The camshaft backorder has been going on since march, part suppliers are saying the first of the year, maybe. I had to purchase a cam thru a dealer and have it "expedited" thru Jeep cares, We will see where this goes. You believe what you want to believe.
alphawolff
california
2021 JLU
If it's likely the engine will quit suddenly that's a safety issue likely to result in a recall. Just look at the GM 6.2L V8 problem.
Very, *very* few recalls are issued because of engine stalls. The 2.4L multi-air had excessive oil consumption that caused a stall for half a decade before they finally got around to making a recall for it, and even then most of them are expired by now.
The 4XE (Grand cherokee) has had a rampant stalling issue since the 95b recall and there isn't a recall for that yet, for example
Some OEMs just wait until NHTSA forcesthe recall, some (like toyota) do it voluntarily. Stellantis rarely does big expensive recalls unless it has no other choice.
Ron Texas
23 Rubicon
Do you have any sense of what the defect rate is? Does .5% sound reasonable or is it worse or better? Is it fair to say that if the engine makes it 60k miles failure as described in the TSB is unusual? As far as recalls go if not forced by NHTSA it could be forced by company lawyers or a class action lawsuit. I don't know of the later which causes me to believe this problem is fairly contained.
Jtphoto
Thunder Bay ON
At this point the original 3.6 has been out since 2011, the PUG since 2017 in some other models, 2018 in the Wrangler. One would think that if the problem was that big a Class Action would have made it through by now.
AVGeek99
Peyton, CO
2025 JLUR '41, 2024 Rubicon 4xe (wife's) Bright White
is performance in a jeep more important than reliability? not just the daily noise you deal with but the fact that youre running a 4 cyl engine in a vehicle that needs at least a 6 but have to "hack it" with a turbo to get it to do what it does?
seems to me over time a 4 cyl engine simply cant keep up
I don't drive it like a performance vehicle, I didn't with my 2021 3.6 6mt either. I was responding to someone's question about if it was faster than the 3.6. I can say without question yes it is, but again that's not how I drive it or why I bought it.
I used to have the same opinion of 4cyl turbos, why not just get a 6? But the Pentastar, especially with the manual transmission is a dog. I don't know what it is like paired with the automatic; maybe it's a lot better. But with the manual, if you're going up almost any type of hill you need to downshift to maintain speed, sometimes 2 gears. Yes, the 2.0l with the auto is downshifting too, but it's so smooth you barely even notice. Driving through hilly terrain with the 6mt was annoying. I've never had a manual that required so much downshifting just to maintain speed.
But the main reason I got a 2.0l is I've had the repair that this TSB is about twice, once at 26k miles and once at 41 or 42k miles. My 2021 is now going on 30k miles since the last repair. It's running fine with no tick, but I know it's just a matter of time. I'm selling my 2021 as soon as I have all my aftermarket stuff moved over. I just have the drag link and bumpers left. Then I'm installing my XR suspension on the 2021 and selling it.
Jtphoto
Thunder Bay ON
I’m curious how the 2.0L handles bigger tires and pulling trailers. I know it’s quicker empty once the turbo kicks in.
Ron Texas
23 Rubicon
I did some AI searches. The 2.0 does 0-60 in around 8 seconds, the 3.6 in around 7 seconds. That's not an opinion, it's a fact.
AmericanPatriot100
Kitsap Co
2025 Wrangler Sport JL
Because the 392 is much more expensive and an LS swap is even more expensive. The latter option is almost laughable...sure...go buy a new JL with a 3.6L and then dump it for a more expensive LS? The vast majority of automotive consumers would never entertain that idea because it just doesn't make good financial sense. Buyers also continue to invest in the 3.6L because it has been a proven engine across multiple vehicles for years and want to believe that their previous 3.6L issues are just anomalies. Statistically they are correct, and your good experience with the engine supports it.
That makes a lot of sense! I think the 3.6 is an awesome motor and I’ve seen some WILD things done to the 3.6. I think the folks who absolutely hate it are those who abuse their engine and then expect it to last. I have buddies like that. Those that refuse to change fluids and then get pissed when it’s smoking and the motor all of a sudden locks up cause it burned all the oil out of it. And yeah the 392 and LS are crazy prices. But I agree with you that folks hope their last 3.6 was junk and their newer one will be better!
Jtphoto
Thunder Bay ON
I know I’ve seen videos of testing and the 3.6 is faster on 87 octane 0-60 but the 2.0 does better on 91 octane.
  • Like
Reactions: AFD
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
I'm pretty sure the 3.6L in a stock 2-door Sport without doors and top at sea-level is ~4 seconds faster than the 2.0T in a 4-door Rubicon X on 37s ;)
But all things being equal, they're pretty damn close.
  • Like
Reactions: gek
flyer92
Nevada
I managed to go 20+ years before I purchased another jeep. Swore I wouldn't do it again for years... 2018 JL with a toasted cam in my garage at the moment. Parts are being "expedited" we will see what that means.
I hear ya. I was 100% happy with my stock 1980 CJ-5 and had no issues until I just had to sell it and buy a JL. I swore I would never do that, but thought I'd be better off in my later years with some "modern" creature comforts like A/C, stereo, cruise control, and uh...doors. Never realized it would also come with a ton of "Jeep things" that make for a pretty disappointing owner experience. Good luck with your repair and please keep us posted!
alphawolff
california
2021 JLU
2.4L Multi-airs had a near 100% defect rate. The concern came from how *much* oil was being burned. In a normal world the owner would've checked their oil once in awhile the issue would have never been noticed in any severity. Instead we had ~7500-10k oil change intervals and the engine was running low on oil around 5000 miles. Some would burn half a quart every 1000 miles and some nearly 1.5 quarts. Capacity of 5.5qrt, at 3qrts low it can exhibit stalls during forceful maneuvers. At 4 qrts low it'll stall just coming to a stop light. This is because it used oil pressure to actuate the intake valves in leu of a camshaft (hence the multi-air part). Without pressure the valves don't open and the engine stalls from lack of oxygen.
Stellantis released three separate fixes to appease the EPA depending on model year. They determined that continuing to inject fuel under coast downs to prevent some vacuum was sufficient enough. This had to be done without changing the MPG standards. Some vehicles only were authorized for the flash, while some got the flash and a consumption test, while others couldn't make the MPG standards with the update and were given complete engine replacements if they failed the consumption test. The newer engines had re-designed piston rings to help reduce oil burn.
They also made it rather annoying to perform the consumption test. The owner had to return between 1300-1500 miles for a follow up inspection. If you went over you had to start all over again. A large amount of owners simply weren't informed and had the recall checked off without ever coming back for the inspection. Even those that got the update done still frequently had excessive consumption. If they were under powertrain warranty we could get them replaced, but they're all well out by now.
The entire fiasco could've been avoided by simply lowering the OCI to 5000 miles. It took a lot of owner neglect to get to the point of stalling, but you can't blame them due to the long intervals I guess checking your oil isn't something people do anymore. It's like modern vehicle owners expect to never have to open their hoods once during ownership.
carlos c
Carlos
ct usa
18 jeep wrangler jlu
Are you getting any help from the dealer? My 18 JL is at 82,000 miles with cam code and misfire code. Haven’t taken to the dealer yet.
gek
Code Monkey
But, it’s not a design problem it’s a parts manufacturing problem. Very few engines are affected. If it was a design problem the failure rates would have been much higher and the engine would have been redesigned.
6MT Owners when reading this
Jeep Wrangler JL Latest TSB on the Pentastar engine {filename}
