Same here. I've built many engines and I know what it takes to build it to survive break in and many years beyond. After watching this video it makes sense why we see some less than 1000 mile engine failures. No real bearing clearance checks and no lube on at least the main bearings or rod bearings during assembly equals scuffed bearings on first rotation. Even if done by hand.Weird, it didn't look like they used any assembly lube.
Could you please explain me about fuse box ?I wonder if they'll ever release a video of the fuse box install ?
Wranglers have been famous for not having the fuses set in the fuse box correctly. one of the first recommended things to check when taking delivery is to push in all of the fuses and make sure that they are set correctly.Could you please explain me about fuse box ?
Thank you very much, my Rubicon is coming in the next 2-3 weeks. Will check this at the dealerWranglers have been famous for not having the fuses set in the fuse box correctly. one of the first recommended things to check when taking delivery is to push in all of the fuses and make sure that they are set correctly.
Np congratulationsThank you very much, my Rubicon is coming in the next 2-3 weeks. Will check this at the dealer
Thank you very much!Np congratulations
A Jeep assembly line worker on this forum says the fuses come pre-seated from the supplier. This makes sense but someone in quality control should be checking them as well.Wranglers have been famous for not having the fuses set in the fuse box correctly. one of the first recommended things to check when taking delivery is to push in all of the fuses and make sure that they are set correctly.
It was supposed to be a funnyA Jeep assembly line worker on this forum says the fuses come pre-seated from the supplier. This makes sense but someone in quality control should be checking them as well.
It was. I gave you a "haha" and then went all serious on you.It was supposed to be a funny
I bet we’ll never see that one.I wonder if they'll ever release a video of the fuse box install ?
