Key fob washing machine blues
Axelbndr
Axel
SF Bay Area
2022 Rubicon 2door, 6Mt, PBJ, Blk. Top, Bl
Key fob went thru wash and now it & backup fob only lock unlock at close range & jeep won’t beep when locking… what did I fry?
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Washing the fob has nothing to do with range or horn of either fob. Change the battery on them both. Then go into Uconnect and see if the horn function is selected or not.
You should fully open the one that was washed and let it dry in some rice as well.
Axelbndr
Axelbndr
Axel
SF Bay Area
Done that, opened, rice. new battery’s in both.. I will look at UConnect but why would that change and why is distance suddenly a factor?
roaniecowpony
Retired Engineer
Order a new one from Benny @all mopar parts. The circuit board is likely damaged. Save the silicon chip and metal key, for a compact emergency key.
RandyP111
Lance
2022 Jeep Gladiator Sport
Just did this too...one new battery, one week to simply dry, works fine now.
Dyolfknip74
2021 JLU Rubicon
Not sure but between the UConnect setting, JScan/Tazer/Something similiar, that's the only way the horn noise would turn off.
As for range, batteries affect that but if you changed it for a known good one, also unsure.
Redcanyon77
Yorktown, VA
2023 JL Rubicon FarOut Edition, diesel
If there’s no evidence of water/physical damage and you’re under warranty there’s a chance the dealer will replace it if it’s anything other than the battery. I’m sure it’s pretty subjective and depends on your relationship with your service advisor.
Dan M.
Albany NY
2020 sport (2 door)
not to beat someone when there down, but how did that happen? these fobs are so big I can always feel when they are in my pocket. maybe the one good thing about them being that big.
Axelbndr
Axelbndr
Axel
SF Bay Area
I typically put it in the small change pocket and it didn’t get noticed on laundry day.. Also I suggest putting a dab of hot glue on tip of key, if ever needed easy to pick off and it eliminates the switchblade in pants issue.
DarthAWM
Mick
Odessa, TX
2021 JT Rubicon
Oilfield Dispatcher/Semi-Professional Adult Film Star
Just wondering how you missed that small briefcase of a key fob when checking pockets?
Axelbndr
Axelbndr
Axel
SF Bay Area
It’s home is the small change pocket.. that location & a little bit of hot glue on tip of key eliminates the switchblade in pants effect.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
You might consider opening it up and loosening the internal spring. That'll keep it from being quite so incredibly annoying.
