Key fob proximity not working
Tommy379
Tommy
Virginia
2018 JL rubicon 2dr manual
To rule out a battery or fob antenna issue in the remote, I read to place the fob near the door handle sensor to see if it will pick up the signal. It said the proximity sensor for locks and start requires a stronger fob signal than the remote lock/unlock.
Maybe give this a shot?
No, that doesn't work with either fob.
Erievon
Al
Cleveland, OH
23 JTR, 21 JLU (Low) Altitude
The batteries were both replaced last summer when I got a warning on 1 of them. They were 4 years old so I assume theyre still good.
I just grabbed the other key and have same issue. Just realized they both open passenger door but not driver door.
Ran codes in Tazer - found RFH B259A-13. Looks like proximity sensor issue.
Anyone have experience or suggestions on this?
OP I can't help, that one is puzzling since nothing is working.
But for you....I've had both of these problems. Either the door handle goes bad, or the wiring harness in the door goes bad. Lucky for you, the door handles are not side specific. Take the passenger door handle and move it to the drivers side (super easy, youtube it if you don't know). If suddenly your driver door works and your passenger doesn''t, bad handle, order a replacement.
If you switch the handles and the driver door still doesn't work and the passenger still does, the problem is in the wiring harness. First check the pins, if all looks good, then you need a new door harness (or you can go hunting down the broken wire in the harness, that's no fun). The break generally happens in that section of harness between the door and the body. The way it was designed it's constantly bending in half. And since you open your driver door likely far more then the passenger one...it wears out quicker.
aeonixx1001
Kim
Arizona
2020 Jeep JL
Because the Jeep starts when you hold the fob against the START button, this tells us:
✅ The fobs are good (the RFID chip is working)
✅ The vehicle recognizes both keys
❌ The wireless keyless-entry system is not working
So this is not a fob problem.
What’s almost certainly wrong
Failure or glitch in the RF (Radio Frequency) system
On the 2024 Wrangler this is usually one of these:
1. RF Hub module
2. Passive Entry antennas
3. Body Control Module (BCM) software or communication fault
4. Low or unstable 12‑volt battery
(still a top culprit)
Since both fobs stopped working at the same time, the RF Hub or its power/communication is the most likely cause.
What you should do next (in the right order)
1. ✅ Load‑test the 12‑volt battery (very important)
Even though the Jeep starts.
A weak battery can:
Kill keyless entry
Still allow push‑button start
Cause RF modules to shut down
👉 Ask specifically for a load test, not just a voltage check.
If the battery fails → replace it → problem often solved immediately.
2. ✅ Try a full vehicle power reset
If the battery tests good:
1. Turn vehicle off
2. Disconnect negative battery terminal
3.
Wait 15 minutes
4.
Reconnect
5. Try the fobs again
This resets the RF Hub and BCM.
3. ✅ Dealer visit (very likely warranty)
If neither step fixes it:
Dealer will scan for:
RF Hub faults
Antenna communication errors
BCM software updates
Common outcomes:
RF Hub replacement
Antenna repair
Software reflash
✅ This is normally covered under the factory warranty on a 2024.
What this is not
❌ Not dead fob batteries
❌ Not bad key programming
❌ Not user error
Temporary workaround (until fixed)
Unlock using:
Physical key inside the fob or
Jeep app (if equipped)
Start by holding the fob to the START button (as you’ve been doing)
One last question (helps confirm the exact fix):
After unlocking manually, does the Jeep lock/unlock automatically when you touch the door handle, or is all passive entry dead?
That tells me whether it’s antenna-related or RF Hub-wide.
Tommy379
Tommy
Virginia
1. RF Hub module
A weak battery can:
Kill keyless entry
1. Turn vehicle off
3.
Wait 15 minutes
4.
Reconnect
RF Hub faults
Common outcomes:
RF Hub replacement
Antenna repair
Software reflash
What this is not
❌ Not user error
Unlock using:
It's a 2018 with a manual. No warranty left. All passive entry is dead. Has new very expensive AGM batteries installed, including the auxiliary.
aeonixx1001
Kim
Arizona
2020 Jeep JL
Did this occur after the Battery install, I am assuming it happened and then you replaced the battery. I would try disconnecting Neg lead on main for 15 minutes. That will reset BCM. If it does not you may have a bad module or antenna. Im sure a remanufactured is available or my favorite junk yard usually always has what I need. People tend to roll them a lot out here LOL
aeonixx1001
Kim
Arizona
2020 Jeep JL
Could even be just a connection came undone
Tommy379
Tommy
Virginia
The batteries were replaced 3 months ago, this problem has just started in the past week. I did disconnect the batteries, including the auxiliary battery, 3 days ago, left it for the day, reconnected, problem persists.
How would I test this antenna to know it's defective? I do not want to throw parts at it like darts i. The dark.
aeonixx1001
Kim
Arizona
2020 Jeep JL
Below is the complete set of modules, antennas, and wiring involved in the keyless entry and lock control system. You can Google or use You tube to see how to test each module. This will tell you where they are on your Jeep and what each module does.. Hope this helps
🚗 1. Body Control Module (BCM) — “Central Brain”
The BCM is the primary controller for:
  • Lock/unlock commands
  • Fob authentication
  • Interior lock switches
  • Door ajar sensors
  • Horn chirp confirmation
  • Lighting flash confirmation
  • Behind the dash, left side (above driver footwell).
Inputs/Outputs:
  • Receives RF signal from the RF Hub
  • Sends commands to door lock actuators
  • Communicates with door modules over CAN bus
📡 2. RF Hub Module (RFM) — Remote Fob Receiver
This is the module that actually receives the key fob RF signal (315 MHz for NA models).
Functions:
  • Receives lock/unlock commands from the fob
  • Sends authentication data to the BCM
  • Stores key fob IDs
  • Controls the vehicle immobilizer handshake
  • Under the dash, near the steering column (varies slightly by trim).
📶 3. Passive Entry Antennas (if equipped with Passive Entry)
If your Wrangler has Passive Entry (touch the door handle to unlock), it uses multiple antennas:
Exterior LF Antennas
  • Driver door handle antenna
  • Passenger door handle antenna
  • Rear cargo area antenna
These send a low‑frequency (LF) “wake up” signal to detect the fob near the vehicle.
Interior LF Antennas
  • Center console antenna
  • Rear seat antenna
These confirm the fob is inside the cabin before allowing push‑button start.
🚪 4. Door Modules (Driver & Passenger Door Nodes)
Each front door has its own control module:
Driver Door Node (DDN)
  • Controls driver door lock actuator
  • Reads door handle sensors (if passive entry)
  • Communicates with BCM over CAN
Passenger Door Node (PDN)
  • Same functions for passenger side
These modules are why the JL can detect which door you touch for unlocking.
🔒 5. Door Lock Actuators
Each door has an actuator controlled by the BCM or door node.
  • Driver door actuator
  • Passenger door actuator
  • Rear door actuators (4‑door models)
  • Tailgate actuator
🧠 6. Sentry Key Immobilizer (SKIM) / Keyless Ignition Node (KIN)
If equipped with push‑button start:
  • Reads the fob’s encrypted immobilizer code
  • Communicates with BCM and RF Hub
  • Allows engine start only when fob is authenticated
🔌 7. Supporting Sensors & Switches
  • Door ajar switches (in latch assemblies)
  • Lock/unlock switches (on interior door panels)
  • Handle capacitive sensors (passive entry models)
  • Liftgate ajar switch
alphawolff
california
2021 JLU
Alphawolff gave you the answer back on page 2 - you need to scan for codes through the OBDII port.
Seriously. I'm almost irritated that we're having a chat-GPT conversation that also correctly assumed an antenna issue, and that wasn't enough so we asked chat-GPT some more.
Tommy379
Tommy
Virginia
I apologize.
Tommy379
Tommy
Virginia
I have noticed, although proximity unlock isn't working, neither is keyless push start, when I grab the door handle, a little red light flashes on the fob. So something os communicating.
aeonixx1001
Kim
Arizona
2020 Jeep JL
Having the codes are absolutely the quickest way to sort out what module or unit is not responding. You can take it to an auto zone or like and get a free code check, quick to do, I agree with Bob.
