Key fob not Detected, fob not operating
rswanson
Carroll County, MD
2018 JLU Sport
This morning my JLU Sport did not start up using the push start button ignition. I had to use the fob pressing the start button, as directed by prompts on the cluster display.
When I exited after driving I noted that the vehicle did not respond to remote locking. I didn't have the Jeep locked last night so didn't use the fob until in the seat.
At work, I popped the fob open and reseated the battery. The Jeep locked and unlocked at approach and started with the button. I figured a drained battery in the fob was the culprit, even though my Jeep is only 9 months old. After swapping the battery with a new CR2450 battery, there is no further response to the fob. The reserve fob is equally useless.
When I first press start, I get a display "Key Fob Not Detected" and after pressing again "Push Button with Key Fob to Start" upon doing so, the vehicle starts. I notice there is a delay when pressing the fob into the button before it turns over. I pulled the starter fuse and replaced but that's about the extent of my abilities here. I do have remote start but that doesn't work, nor does the panic button. In short, the Jeep is not responding at all to either fob, save pushing into the start button.
I've done a web search and forum search but nothing conclusive. Anyone have similar issues or ideas before I contact the dealer? Thanks!
W1ck3d
Toledo
2019 jl rubicon
Might be a problem in the rf hub or something going on in the bcm.... Unless somehow the battery is not sitting right in the fob
rswanson
Carroll County, MD
2018 JLU Sport
Thanks for the reply. I can rule out the battery issue since I switched out the battery in one and both fobs provide no functionality.
Update- this morning all the same symptoms still exist but in addition, I had a passenger exit from the right front seat and I get a message stating "Key Fob has Left the Vehicle" which persists even after the door is closed. I have both fobs with me. It seems like they're not being recognized by the vehicle. Any guesses?
Rhinebeck01
Multiple places..
@rswanson
Have the JL, flat bedded (not towed) to the dealer. FCA pays for the flat bed. Call this number: 1-800-992-1997
The component (rf hub) on your JL that deals with the fobs has apparently died or ..........
Highonlyfe
IA
2018 JLU Rubicon, 2011 JKU
@rswanson
This is unfortunately your best option it sounds like
rswanson
Carroll County, MD
2018 JLU Sport
@rswanson
I can drive the vehicle. I just have to press the fob into the starter, as if the battery in the fob was dead. Then, she starts up and drives normally.
Actually, I now have to add "HAD to press the fob..." because the issue has resolved, at least temporarily. After my passenger got out of the vehicle and I got the message that the fob was not in the vehicle, I drove on to work and left the message on the gauge cluster display. It stayed on the display during the entire drive in. When I arrived, I shut the Jeep off. And....all works normally...fob, start button,
everything. Whatever got out-of-whack is now in-whack.
Puzzled....but hope it was an anamoly. I'll update for reference if the condition returns.
ALRUI
Arnold
Murphy, NC
2018 JLU Sahara, 2003 F150 S-Crew FX4, Others
Did this ever crop up as an issue again? My wife had a similar experience last night. FOB battery is barely above nominal 3V but still good (I ordered a couple new ones anyway). Please advise & Thanks!
WRANBO
Marco
Ontario
2019 Jeep Wrangler
I’m having this issue right now… did you figure out what caused it?
Opus
Midwest US
www.jlwranglerforums.com
2023 Sport S, 2021 Compass
Maybe a silly question, but the batteries you swapped into the fobs were new batteries, correct? Not ones that have been sitting around a while?
ALRUI
Arnold
Murphy, NC
A brand new battery and the issue never occurred again. Put a fresh battery in:)
Fudster
Elliot
Athens, GA
2019 Sahara
Did I miss it? Why wasn't the second fob provided by Stellantis with the vehicle tested as as control?
AnebuR
CT
2018 JL Rubicon + 2014 JK Sport S
Had one fob fail on me. Just to test things out, the same battery works just fine when inserted into my other fob. Tried a brand new battery as well. I'm assuming something on the fob's board failed.
