LunchBoxFab
where do you think we all came from?JLwranglerforums is quickly turning into Pirate4x4. Lol
My wife's car does that...annoying as heckMy F150 (that I replaced with the JL) had that stupid honk feature if you got out and closed the door with the vehicle running. I understand the idea of the feature but it was so annoying and loud and rude to others anywhere near the vehicle.
Not that I can think of. I'm sure some would dispute it over a very specific situation, but for 99% of the time, if the car is in park or not moving while the key fob is not present, that should be an indication it can and should safely shut off.If the car shuts off after 30 minutes (or 60 minutes or whatever) of there being no key fob detected and the car not being moved, wouldn't that solve the problem? Any downside to this?
Oh, I can tell who came from there. Lolwhere do you think we all came from?
Oh the ironyyoure*
and "own" - credit aint for everyone...
There’s a cut off time If you use the remote start to start it, but I’m not sure how long it is.The best part about this thread is that I learned by new JL will NOT shut off after 5min of warm-up idle time when it's -40deg outside next winter.
Yeee-fuckin-ha
I think I read somewhere that it is 15minThere’s a cut off time If you use the remote start to start it, but I’m not sure how long it is.
About 10-15minsThere’s a cut off time If you use the remote start to start it, but I’m not sure how long it is.
Understand your point but at some point in time we need to move on. The keyless entry/no key/etc..... has been around for a while. Years even, we have to at some pint, understand what we are driving and get used to it. Going to the mall and your wife saying, go get gas while I go shop, should trigger a response lie "where is the key?" "I need it to drive this car". BREAK habits and learn new things.Okay, Internet keyboard catfighting aside, let’s bring this back to the realm of seriousness because it’s actually a really interesting topic with serious implications (spoiler: I’m going to bring up Anton Yelchin).
Earlier in this thread someone said something about how it’s our responsibility to operate the vehicles safely, not Jeep’s. Thanks for posting this because it brings up the interesting philosophical question I’m going to raise with regard to design: what obligation does the manufacturer have to design a car that is safe to operate? Where’s the line between intuitive, familiar design and innovative design that is needlessly changed for no measurable benefit? Is there a point where change for change’s sake can be harmful?
Let’s set aside key fobs for a moment and examine the automatic transmission selector lever. For decades, automatic transmissions tied the physical location of the shifter to the gear you’re in (Park, reverse, neutral or drive, most commonly). With your eyes closed you could grab the shifter, push it forward, feel it move through the gates and hit the limit of advance- park. You could then exit the car with your eyes still closed and be certain it wouldn’t roll nowhere. The design communicated something to you and you naturally can operate it without thought, much like the entire process of a daily commute. Then FCA engineers changed that and removed the physical connection to the gear you’re putting the car in. A Grand Cherokee was erroneously left in Neutral and killed Chekov.
Could this tragedy theoretically have happened with a traditionally-gated shifter? Sure. Is that likely? Hell no. To be fair, this wasn’t likely either- but it was enabled by a needless design change. FCA quickly changed the GC’s shifter design (if memory serves).
Bring the topic back around to key fobs and it gets a little muddied. There IS a measurable benefit to not having to remove a key from your pocket or purse, insert it in the ignition, and turn it. Pushing a button IS faster. That’s fine. But then you add the “feature” of ESS and it muddies the water again: you park your car, the engine shuts off, and maybe you even touch the push-start button, but not hard enough for it to register and your car is still on. Later the engine kicks back in to maintain the HVAC temp, and your garage fills with CO. Once again, removing the physical act of twisting a key counter-clockwise and pulling it to the right- something you can do with your eyes closed and be sure you did it and be sure it registered- removes an analog step and replaces it with a digital one that must be verified with your eyes and a conscious thought.
Is it worth the time saved by not having to remove the key from your pocket? I’ll let you decide.
Sorry I misspelled a couple of words, for the word police. I was thinking pint and wanting to write POINT..... I wanted to LIE but should have written LIKE. So there you go.....Understand your point but at some point in time we need to move on. The keyless entry/no key/etc..... has been around for a while. Years even, we have to at some pint, understand what we are driving and get used to it. Going to the mall and your wife saying, go get gas while I go shop, should trigger a response lie "where is the key?" "I need it to drive this car". BREAK habits and learn new things.
