JL - Trailer Brake Controller
traviswalker007
Tony T Walker
Phoenix, AZ
2018 JLU Rubicon
I just picked up my 2021 6x12TA enclosed yesterday in Tucson and drove back home with no brakes so its sitting in my drive way I doubt its any issues on trailer side.
traviswalker007
Tony T Walker
Phoenix, AZ
2018 JLU Rubicon
I figured it out!! I ended up tracing all wires from jl side for correct power output while boosting trailer brake manually and everything was reading ok. So I traced all wires from my brand new 2021 enclosed trailer and found a ground wire not fully connected in cable management box?? so I wired them up tight and checked the rest and boom works perfect with no dash codes. Pretty sad you spend close to 6k on a new trailer and have to spend half a day fixing shit.
Plongson
Paul
So. Utah
2020 Wrangler Rubicon JL Diesel, 1984 Jeep Cherokee XJ
Retired engineer and business owner. Vibration analyst, reliability specialist.
I'm here to dig up old bones...lol.
I got the OEM controller and it's installed, push the override and it throws errors. Reading this thread, I got the idea to buy the Tekonsha 3024 cable with the diode and switch the wires.
What has me wondering is...the black is 12v constant and the blue is the brake power wire. I'm assuming the red get the diode. Why are we swapping the blue and black?? And when you do, do you lose 12v constant power to the trailer (charge the coach battery)?
What am I missing here??
Thanks!!
JLURmojito
Wisconsin
The black at the controller plug is different than the black at the 7 way connection on the rear of the vehicle.
The controller needs constant 12v+ then uses that to send modulated power to the brakes via the blue wire.
Plongson
Paul
So. Utah
Gotcha...I'm getting the new pigtail tomorrow and I'm sure it will make sense once I have it on the bench.
THANKS!!
kkarnage
2022 392, 2020 JLUR, 2015 JKR
THANKS!!
I'm interested to find out whether you've come right with the new pigtail. I installed my OEM controller today, and it all works as expected, except those errors it throws when you hit the override. I'm a little annoyed that the OEM kit does this: one would be forgiven for thinking that they had tested it on a real JL in real life and noticed the errors? Anyhow, any updates you have would be real welcome. And maybe a quick synopsis of what cable you ordered (and a link, if possible), cable color swapping etc, just to have a solution for the OEM controller all in one place, instead of having to scroll through 14 pages of conversation to figure it out (I'm a lazy bastard like that ? ).
Plongson
Paul
So. Utah
Man, has this been the ordeal...Ya, I finally got it all worked out and it works perfect. Follow this thread post 70-72 and will answer all your questions. I think Mopar/FCA is a piece of shit for releasing this monster on unsuspecting souls...
Good Luck!!
Brake Controller...
kkarnage
Good Luck!!
Brake Controller...
Awesome, thank you! So, the problem is basically that the OEM harness, made by Mopar, specifically for the JL and JT, doesn't have a diode? Did they not test the damn thing before they started shipping it? Sadly I can't say it is entirely surprising: FCA quality control and all...
Plongson
Paul
So. Utah
Exactly what you said. My OEM cable is in the junk drawer, but the system works now.
kkarnage
Can confirm, Tekonsha 3073-P fixes the problem, and is a straight swap for the OEM cable, no messing around with pins or other things. The only challenge is that it's a right PITA to get the controller-side plug from the new cable into that socket. There's not a lot of room down in that footwell.
Quadjeeper
Winter Springs, FL
2022 392XR
retired
True that. On both counts. It fixes the issue, PITA to install. Just replaced my harness.
Popgun05
Steven
Sandusky Ohio
2020 JLU RUBICON
I have 2020 JLU Rubicon and this is what worked for me. Purchased Tekonsha 3014-P off Amazon. Had the dealership flash my computer and added trailer options (AHT/AHX) and performed TSB 08-019-21 flash on ABS module that was just released 1/30/2021. I have an aftermarket Reese brake controller that was in my JK and was getting the traction control light when I’d plug it in. Now with these updates and flash all is GTG.
JoBuck
Jodie
Corpus Christi, Texas
2020 JLUWD Sarge Green
I installed the red arc brake controller in my Jeep and my Jeep did not come equipped with a factory tow package. I tapped into the third brake light wire. I traced it from the light to the right side rocker panel . If I remember it was green and tan. I posted pictures on this a couple of months ago. July or Aug time frame.
Punkn Expo
Tom
Pennsylvania
2018 JLU Sahara
For reference, I have a JLR with the factory tow package. I went with the Redarc Tow Pro Elite. I ordered from etrailer.com and they had a new pigtail adaptor that allowed a complete plug-n-play application...no swapping wires required. Plugged right into the factory tow harness found under the dash and worked perfectly with no dash lights or other unexpected issues. The adaptor from etrailer added about $20 to the already pricy Redarc unit but it installed relatively easily and I love the diminutive control knob. Also much easier to adjust than the Tekonsha I had in my previous tow vehicle.
Thanks for your post. I was looking at this on the e-trailer site and was curious how well this worked, I assume the Tekonsha 3073-P harness you bought has the diode and doesn't light up the instrument panel at all? The two connectors you need for this setup are really pricey. I'm about to buy the Redarc but the Tekonsha 3073-P Jeep Harness at e-trailer adds $113 to the cost of the brake controller itself ($208), while the Redarc Adapter is still the same $20. This compares to the Tekonsha 3024-P that JLURmojito describes earlier in this thread which cost $18 on Amazon, which would be all you need if you simply rewire the brake controller end of the 3024P harness to the Redarc adapter that comes with the brake controller itself. Gonna give this less expensive option a try and hoping I can save some money without any issues. Thanks again.
