JL Rubicon caster measure
dannko
Bee Cave TX
2018 Rubicon JL Unlimited
Jeep Wrangler JL JL Rubicon caster measure yok
DIY'er's for measuring caster, is the flat part of the bottom of the yoke an accurate place to measure the degree of caster?
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
You can. I use the holes on the front of the diff next to the cover and the flat spot on the pinion. I shoot for 0 at those locations. Should give you 6 degrees caster or just about
Csward12
Chad
Corona, Ca
2018 Jeep JL Rubicon
Law Enforcement
Can somebody PLEASE take an accurate picture of where to check castor on the JL?
Csward12
Chad
Corona, Ca
Law Enforcement
I’m curious to to where I am with the 2” Mopar, and I’m going to the full 3.5” MC Rocksport in two weeks.
Rock Krawler Suspension
Tech Support
Waterford New York
rockkrawler.com
Red JLUR, White JLUR, Yellow JL (3 so far), Bikini Diesel JLU, Billet JT, Hydro Blue JT
These two holes?
No, the part circled in green here. The surface there is machined flat and you can put an angle finder on them accurately.
Jeep Wrangler JL JL Rubicon caster measure Inkedupload_2019-4-3_15-46-9_LI
RonAZ
Ron
Scottsdale, Arizona
Does the rear axel have a caster setting as well? Sometimes it feels like the tail is waging the dog when it comes to trying to drive straight down the road.
My front is at 4 degrees per iPhone app. Is it possible the they are just welding the bracket on the frame at the wrong location on the front?
Solidaxle
Beautiful Ventura county California
2019 JL 2 Door Rubicon
Ah ok, I was wondering how you'd use the two holes I circled lol
Thank you!
Just in case anybody wants to know why the Dana axle has those holes , it’s for a case spreader. It has two pins that spreads the case open to change the carrier.
CaddyshackGopher
North Dakota
2019 Sting Gray JLUR
So I’m getting 2 very different numbers between going from the flat circles on the pumpkin vs the flat area on the knuckle. Can someone explain which area is the correct one to get a solid “home” read on caster? Thanks in advance!!
mysto
Sting Grey 2 door JL Rubicon
I just have an angle finder, but I'm at about 7 degrees on the knuckle and 1 at the pumpkin. Someone abo ve suggested adding 6 to the pupkin, which approximately matches what i see.
CaddyshackGopher
North Dakota
In this scenario is your caster 1, 6, or 7?
