JL Rubicon caster measure
Kev84
Kevin
Westfield, IN
2019 Rubicon
I just found this in the description of the kit I bought with those arms in it...
• Preset front lower Sport Control Arms balance front caster and pinion angles on 2.5” lift kits
• 1.5” lifts = more caster; 3.5” lifts = less caster
2Wheel-Lee
Lee
Orange County, CA
2020 JLUR, 2006 Dodge Ram 2500 CTD, 1986 Suzuki Samurai, 1975 Datsun 620
The pumpkin is 6 degrees off of the caster. So if the caster is at 6 degrees, the pumpkin will be at zero (or a vertical 90, depending on how you set your gauge).
I haven't checked to make sure the lower knuckle surface is a good place to measure, but based on the measurements noted above, they corresponded to being 6 degrees off of what was read on the pumpkin, so the lower knuckle does appear to be a good place to measure caster. .
Cypher
J
AZ
Cybersecurity Leader
I have a stock height JLUR, but weighted down with armor, bumper winch etc. I also have the Mopar LCAs. When measuring the diff holes I get 88.7*, and measuring the flat spot under the knuckle I get 8.7*. Mine actually drives really nice, but may be lifting soon and want to get at least back where I am now.
I zero'd out my Klein digital angle finder at 90 degree vertical and it is now showing 1.3*. It looks like to be at 90* I need shorter LCA, or longer UCA.
I am assuming I am running about 7.3 degree caster correct? This is new to me and I am a little confused. I have adjustable UCA on the way to go with my Mopar Lift LCA so I can get this dialed back in after a lift to keep it driving as nice as it does now.
blnewt
New Mexico
Just ask @cosine he knows!
Haven't heard of any unlifted Rubis that only added the Mopar LCAs w/ caster over 6 degrees, I would think there may be a degree of error there.
Cypher
J
AZ
I thought so too, I set the digital gauge with a level and square, same results. I can zero it out and it reads 1.3, or just use it as is and it is 88.7 I have done thins about 10 times and it is always the same.
my JLUR is a pig, it is really weighted down and on 35s, so that may be throwing it off a bit. Side by side with another JLUR on 35s with no lift I am about 3/4 to 1" lower. I may play around later and jack the front end up to simulate a 2.5" lift to see where it measures at, or how much I need to lift it to get to an even 6 degrees.
blnewt
New Mexico
That weight would alter the caster angle and 1" lower would equate to about a .75 degree change, so maybe your caster is closer to 7. Sorry but I skipped right over the drop your extra weight was causing :(
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
Mechanic
The knuckle reading is easy to get a incorrect reading on. The 7.3 is probably correct. The only real way to find it would be an alignment performed by someone competent. With the Mopar lift having longer lower control arms, and you ordering adjustable upper control arms, and the current portly stance of your Jeep, I think that you will be just fine. The Mopar arms aren't always long enough to get the caster corrected, but with your Jeep sitting lower currently due to the weight, you aren't likely to get 3.5 inches from the lift that some folks get. So you should be able to get your caster back to 7.3 or very close, and be happy with it.
blnewt
New Mexico
Honestly I am not sure I would want to lower it down to 6 degrees. It really does drive amazing now. It drove nice before with the Mopar LCA and Fox ATS stabilizer, but the @Clayton Off Road Adjustable track bars took it to the next level. I worry if I drop it back to 6 degrees it may wander a bit more. Right now even my wife is amazed driving it as it really does drive pretty much like an f150. Still no Grand Cherokee, but really good for a 4x4.
I will evaluate it after the lift goes on to see where it is sitting, and how it drives. I think it may be about perfect with the Mopar lift as far as getting back to 6 degrees, but if it tracks worse I know how to get it back to 7.
I'm a fan of heavy caster, I can see why you'd want to stay as-is, and if I were to lift mine any further I'd opt for more adjustable parts to gain even more caster. Just don't want to get into pinion angle issues so there is a line that can be crossed, but seems like all is well w/ your ride :)
cactusflier
Taun
Phoenix area
2020 JULR, 2006 R53
Retired American Airlines Airbus Pilot
I have a stock 2020 Rubicon and using the measure app on the iPhone I am getting 1 degree at the pumpkin and 7 degrees on either knuckle. So is that telling me I have 6 degrees caster? I was under the impression stock Rubi's are around 4.5 degrees. I was going to order the Mopar Lift LCA's but now I don't think so.
Cypher
J
AZ
I read in the past that the 2020s had more caster built in. I am starting to think there may be something to this from your experience, mine and a few others recently. I know for sure my 2020 is 100% better than my 2018 or 2019 was. I wish I took some measurements before I had the LCAs swapped. I did it pretty much right off the lot though since I had issues with my other ones.
blnewt
New Mexico
Would be interesting to get an alignment verification off a bone stock 2020 JL Rubi as a baseline. That need for 6 degrees caster may have made it to production???
