Interior/Exterior Storage Ideas Area
AnnDee4444
'18 JLR 2.0
I like this... wonder if there's a more engineered solution that mounts a fire extinguisher here.
Installed the H3R-MX250B extinguisher on the H3R-NB300 quick release mount. Worked perfectly on that flat trim panel between the rollbar and the side window on the hard top. It’s accessible from both the back seat, and the tailgate area:
Product links found in this post: JLUR Fire Extinguisher
Detailed mounting instructions in this post: JLUR Fire Extinguisher
Edit: Found this, but it's a little more obvious https://mountainoffroad.com/products/jeep-jl-2-door-fire-extinguisher-bracket
Jeep Wrangler JL Interior/Exterior Storage Ideas Area JLFIREB2D.4@2x
WhtRubi
San Diego
2021 JL Rubicon
MRH512
Wrangler Rubicon JLU
I got this 3-compartment trunk organizer off amazon. It fits in the rear with the seats up perfectly. I keep mine tight towards the passenger side and it gives ample clearance for the door latch.
https://www.amazon.com/gp/product/B07R81J2Y9/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
I keep cleaning gear, work gear, and emergency gear in each of the 3 compartments. it has grippy feet and doesn't shift around at all
I have a similar one with a cooler. It also has straps for the tie-down loops, which can be helpful when it's filled with bourbon and/or beer. Folds up nicely when not need, too.
<https://smile.amazon.com/dp/B0838Y5XHY?psc=1&ref=ppx_yo2_dt_b_product_details>
Jeep Wrangler JL Interior/Exterior Storage Ideas Area 1636050301948
Rescue119
Rescue119
Cory
Trenton, ON, Canada
2021 Jeep Wrangler Willys, 2021 Jeep GC L Limited
Simple shelf setup. I have another single level shelf that goes in front of this one for when the rear seat is out.
Isn't the rear seat out now? Lol.
Rescue119
Rescue119
Cory
Trenton, ON, Canada
This should fit behind the rear seat right.
Jeep Wrangler JL Interior/Exterior Storage Ideas Area Screenshot_20211106-092316_Amazon Shopping
Joe98
Sydney
2019, 2 door Sport S, Mojito!
I was going to install a shelf, made of either plywood or aluminium. The thing is, that my wife likes to push her seat back on a long drive, so the shelf cannot be made of a hard material.
Therefore I used a net to make a shelf. It is designed as quick release for easy removal. The other benefit is that things don't move around as they get caught by the net.
Jeep Wrangler JL Interior/Exterior Storage Ideas Area IMG_1552.JPG
four low
central New York
2018 JL
I made a couple shelves.
Carry two fuel containers on DIY aluminum plate.
EBay $40 aluminum RV roof rack that weighs 6 lbs. and easily modified to fit a JL's roof.
I found a damaged bicycle receiver carrier that has a tilt down, fold up feature and added it to a basket. Bicycle mount also raised the elevation of the basket for better departure angle.
and on my last ten day outing I simply removed the 4 seat bolts and put a plywood platform in place of the passenger seat. under the platform I carried pouched tools and straped a 45qt cool on top.
I like the way the Carry Rack folds up to give some protection to the fuel cans, and acts as a theft deterrent if locking pins used. Great " Repurpose"
The_Irish_Weaver
Long Island, NY
2021 Wrangler Sport S - 2-door - Manual
I had the Tuffy Tailgate Box when I had my 2 door and it was very useful. I removed the tailgate liner to maximize space.
that is really cool - does it add extra rattle as you drive? is it well made and install cleanly? really like this! (sorry for all the questions)
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
I won't use the rear seats very often so when i get my 2dr with softtop i plan to install tuffy deck. It's for that extra peace of mind when going on road trip to the mountains or wherever, leaving jeep in a parking lot while having lunch etc.
I wouldn't leave anything valuable in it overnight though. I've had enough stuff stolen from my past jeeps going back to the 1980s to know that if a thief wants into a lockbox, they can be pretty determined to get in.
I put one on and it works great. I use it with or without Hardtop on.
Jeep Wrangler JL Interior/Exterior Storage Ideas Area Cover
blnewt
New Mexico
Just ask @cosine he knows!
Anyone have this cover?
Seems to be the only one that is an actual cover not a cargo area mat when you search for covers.
I like that it works with the rear seat in all positions.
Looks good, unfortunately out of stock, did you go to gpcs.us or another site for that shot you posted?
RagTopDeluxe
Julie
Northern California
2020 Punk'n Recon
Hi Brian, it is very well made and solid. I installed it directly on the tailgate (removed the plastic tailgate cover) to save space. I put insulation tape on these sections of the tailgate to prevent rattles and scratches (re-posting the pic):
Jeep Wrangler JL Interior/Exterior Storage Ideas Area IMG_6191-X3
I did notice a slight rattle when going over bumps so I put a little foam tape in the upper corner where the lid met the box and it never rattled again.
jonboy
Jon
NorCal
2021 JLR (stock), 2012 JKUR (one tons on 39s)
Are there any options for a secure rear area in a 2dr? I see the Tuffy that bolts onto the tailgate, but I'm looking for something like the Tuffy security deck for the JK that provides a fully enclosed area that you can't access without being able to open the tailgate...
