Interior/Exterior Storage Ideas Area
4xFUN
Scottsdale AZ
2024 2-door Ruby-X, 2020 2-door Ruby, 2023 RAM TRX
FWIW: the 4-door's OEM subwoofer might fit in a 2-door without the back seat.
I'm in the camp that occasionally uses the back seat and while it's never been removed, it often remains in the folded position. I think I can make the JL Stealthbox work by either modifying the large bolt-on front cover/grille or possibly fabricating a new one...Will have to wait a couple weeks till my '24 JLRX arrives to know for sure but I expect this area unchanged.
The thick front grille is purely cosmetic, not used to secure the enclosure or protect the driver. I think I can mill it down to clear the seat when folded. Other option is I know someone with a large 3-D printer and could probably get a new thin grille made and just use shorter bolts to attach to the enclosure.
Jeep Wrangler JL Interior/Exterior Storage Ideas Area Screenshot 2024-04-29 at 8.23.23 AM
Space on my '20 JLR when seat folded...Looks like it could work! The only real tight spot I see (without test fitting) is where the grill tapers outward towards the bottom where you see the carpet angle out, multiple ways to deal with this...
Jeep Wrangler JL Interior/Exterior Storage Ideas Area IMG_5601.JPG
AnnDee4444
'18 JLR 2.0
AnnDee4444
'18 JLR 2.0
AnnDee4444
'18 JLR 2.0
AnnDee4444
'18 JLR 2.0
Wow. I really like this. Removing it would be super simple
What I would really like is if both side brackets had a packout mounting plate, and the center rack also had packout-style latches on either side. This would make for an easily removable rack and be swappable to anything packout.
Something like this on either side (sorry about the 4-door)
Jeep Wrangler JL Interior/Exterior Storage Ideas Area jeep-wrangler-jl-interior2
So you could alternatively mount things like this:
Jeep Wrangler JL Interior/Exterior Storage Ideas Area PXL_20230501_204908575
-lenny-
Boyd
Alberta
JLUR EcoDiesel
Any further updates? I need to mount a full-size packout first aid kit, thinking something over rear side window if it works with Rhino Rack Backbone.
