Hinge corrosion - affects certain colors?
If you are experiencing hinge corrosion, what color is your Jeep?
  • Total voters
    96
JayJay
Johnny
North Georgia
'20 JLR
Interesting, if that's the case, why even add the gasket if it's just aluminum on aluminum?!
I've been wondering the same thing. I've also wondered if anyone has actually removed a hinge to check a "said" gasket.
JeepViking13
Northeast
www.youtube.com
2022 Willys Xtreme Recon 2022 Ford Bronco
It's really easy to tell if you have the gasket. There is zero gap between hinge and door without gasket. With gasket, you can see the gap.
Looks like I have the gasket. There's definitely a gap and it looks like a think black pad that you can barley see. Unless that's dirt build up. Lol.
The question is did they solve the problem on the rest of the vehicle as well? I've seen the corrosion on the front window frame and hood for example already?
Jeep Wrangler JL Hinge corrosion - affects certain colors? 20220822_190031
Rico1111
Rico
RI
2018 Rubicon 2 door JL
So then It is continuing! they seem to have tried to address the hinges but nothing else! New territory for them I guess, maybe they should have a discussion with Audi's reps to find out and implement a better way(not that they will) much like the electronics....seems they are out of their league on these issues. Not enough research and development to understand future issues over at least a five year ownership! Hell even three years. Yet Some car companies have this all sewn up! I know they all have their Achilles heel but paint and clutches and electrical issues ...pick one at least and put it to bed..Do the work!
TheNewGuy
Wes
NH
My '21 appears to have a gasket. One person commented last time I posted it that it just looks like an unpainted seam but there certainly looks to me like there is something between the hinge and the door
Jeep Wrangler JL Hinge corrosion - affects certain colors? Resized_20220501_210942
JeepViking13
Northeast
www.youtube.com
Hard to tell by your picture. It looks like a gasket but then if I look hard enough from my end it also looks like unfinished paint. Can't tell.
Is there a gap when looking at it in person?
TheNewGuy
Wes
NH
Looks just like yours
blessidsoul12
Jordan
Walla Walla, WA
2018 billet silver JLUR, 2019 chevy suburban
Billet Silver here.
I plasti-dipped the shit out of all my hinges early on in 2018. Far as I can tell no rust and no rock chips ?
ELJL
Ed
Fairfax, VA
22 Wrangler Unlimited Rubicon
Likely moisture barrier and friction isolator; doors on hinges move and twist with frame and when opening/closing.
they likely reason that any moisture on the hood will be evaporated/dried out faster with airflow and engine heat.
dem engineers looks for the simple solution. I bet theyre using an anaerobic compound on the threads now.
hats off to jeep for quietly slipping a design solution…. ‘Let’s see if this works’
JeepViking13
Northeast
www.youtube.com
Yeah I really hope for sure they are tackling the issue and have the fix already in place. Fingers crossed. I guess I'll find out over the coming years. Hopefully it works. ?
Bill_P
Orange Va
2018 JLU, 2023 JLUWSXR
Can't tell you..shhh
The only thing with trying to pinpoint paint as a possible cause is that Chrysler is having the same corrosion issues with other models as well. When I took my Jeep in to get a warranty claim filed the service writer said that they were having all kinds of corrosion problems with their Pacifica model as well. In order to get a full picture of whether the paint is part of the issue, you would need a sampling of those colors and combinations as well just in case they are available in colors that Jeeps aren't.
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
If it affects all colors equally, the poll will show it affects the most popular colors the worst.
I believe you’d have to offer a control variable for no corrosion on each color as well, and then compare the ratios for each color
KSwilly
KSwilly
Karl
Culver City, CA
2020 JLU Willys in Hellayella
yeah, there’s gonna be some bias in the numbers for a number of factors - it’s still early, but I’m already seeing higher numbers in some of the older colors. Mojito, for example. Is it the paint? Or the fact that those Jeeps are more likely to be 2018-2019 models? Or just more popular, as you say? Analyzing the data can be tricky. Still, it’s interesting to see it unfold. I may do a follow-up poll in one of the general forum areas to see what are the most popular colors, and weight it accordingly.
