Hinge corrosion - affects certain colors?
If you are experiencing hinge corrosion, what color is your Jeep?
  • Total voters
    96
KSwilly
KSwilly
Karl
Culver City, CA
2020 JLU Willys in Hellayella
Interesting - the Sting Gray forum has more posts than any other color -over 11,000 posts, but has a low number here. Data suggests it may not be as biased based on popularity.
OldBlue
Doug
Chatham Twp, OH
See my Signature
Aerospace Forgings Test Lab
We have 3 JL's, but I could only vote for one. Fortunately we only have 1 showing the effects so far - the '20 Mojito. Both my '21 HellaYella and my daughter's '22 Snazzberry are good. Not sure how your poll could take age into effect, since I wouldn't expect to see corrosion on a brand new one.
--EDIT--
The Mojito is also experiencing hood corossion.
pangmaster
Nathan
Mid Michigan
2018 JLR
Enterprise architect
I didn't notice any corrosion on my 2018 (granite crystal) until after its 4th winter. I suppose I could have missed it, but I don't think it was there for the first 3ish years.
My wife has a '21 sarge green JLU and so far it's good.
OldBlue
Doug
Chatham Twp, OH
See my Signature
Also, just to correct things posted earlier, the doors and hood are aluminum. The tailgate is magnesium. The bolts and the plate it screws into (at least inside the doors) are steel.
Thane
Thane
Dana Point, CA
21 JLURXR, 10 FJ Cruiser
Without knowing quantities produced is each color, the poll is inconclusive...
...unless a massive trend develops.
Jihx
Minnesota
2022 Jeep Wrangler Rubicon XR
Can you add Tuscadero Pink? New color but i'm sure within a year or two we will start seeing it on some of the late 2021 models.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
The hinges are aluminium and yes the bolts are steel along with the plates the screw into. I think I may have said earlier the bolts were aluminium.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
Done! Thanks! Can’t believe I forgot about ChunkinPumpkin! I originally wanted that color but it was so hard to find!
Why did you add the extra description to it?
LLRubylady
Lisa
NY
was an ‘18 Rubicon Mojito! now a boring Mazda
20 JLU in billet has it.
20 JT in Granite does not.
Some other data to throw in there.
The JLU was a rental prior to me getting it and was washed regularly. It lived outside of the salt belt.
JT was a private vehicle. Not washed regularly based upon some areas the dealer missed. Lived in the salty state of Indiana for 2 winters before I purchased.
Starting to think it may be accelerated by regular washing adding some ions to the surface between the two components.
Don’t forget that somewhere in the my21 range the started to put gaskets between the hinge and door on some vehicles.
Why only some vehicles?
LLRubylady
Lisa
NY
So the plates that the bolts screw into are inside the doors, which are aluminum. How to you coat that? You could coat the bolts with a corrosion gel. You could do that with the plates too?
Dyolfknip74
2021 JLU Rubicon
Technically you don't have to. Both the screw and the recieving plate are steel. I am not in the camp that this problem is galvanic corrosion. I think it comes down to :
1. Shitty prep/shitty paint
2. Painting the hinge while attached to the jeep.
That explains why people are getting the bubbles in spots where it's just aluminium. Water is getting under the paint.
HushJeep
BC, Canada
2021 Rubicon 4xe; 2024 Willys 4xe
I’ve read most threads and posts regarding bubbles in paint, corrosion and rust on JLs. This is what I’ve learned:
- Doors and hinges are aluminum, bolts and nut plate inside door are steel;
- Doors are painted at the factory with hinges already attached (I.e. there is no paint between them);
- There is no evidence of a protective coating, primer, gasket or seal between the hinge and door, or between steel bolt and aluminum hinge;
- Has affected people with Jeeps in dry climates, who never drive in poor weather, garage kept and meticulously maintain them as well as others in wet areas with salted roads and less washing;
- Possible and likely major cause is galvanic corrosion caused by dissimilar metals in contact with one another;
- Other causes may be poor paint preparation at the factory (I.e. dust, contaminants, inadequate coverage, etc);
- May not affect all Jeeps but affects a disturbing proportion of them.
A warranty claim or repaint will postpone the issue a few years according to owners who’ve gone that route.
Regarding hinge areas, if you’re going to be proactive, go in 100% (I.e. coat, seal, isolate, paint) as a few have done!
Regarding corrosion at edges of hood or doors… not sure.
Dyolfknip74
2021 JLU Rubicon
Also it looks like newer ones they are painting the door and hinges seperately. Some members have seen a type of gasket or at the absolute least, a gap where the old ones didn't have a gap between door and hinges.
LLRubylady
Lisa
NY
That’s good if they are addressing the issue now.
but still you have to treat the nut plate inside the door with something
Dyolfknip74
2021 JLU Rubicon
Well, technically it's steel on steel so, I don't think so. I looked real close at mine when I had them all off and none of the backing plates was showing any corrosion. Granted I didnt have any bubbling before I did my hinges in LineX though either. I don't imagine it would hurt to coat them if the hinges are off anyway.
