head gasket swap after P0301 code
RenegadeT
RenegadeT
Tony
North Carolina
77 CJ-7, 99 XJ, 2018 JLR
No i think you were right the first time as the nubs on it make me think it sits inside a groove on a piece. Like the other gaskets that came in that bag.
I seem to remember the intake manifold gaskets having those nubs no?
Right. I'm not saying my pics shows it installed correctly, I was just checking diameter. If I unbolted.the TB from the intake, I think I'd find that seal there, and a correspnding groove in the intake.
RenegadeT
RenegadeT
Tony
North Carolina
Getting closer to finishing.
I have 5 connectors that got damaged during disassembly or just arent cooperating.
2 coil packs on the pass. side, the alternator signal wires, and the TB all got the little ramp wiped off. Guess I'll fashion some zip tie retention system.
The small connector on back of the AC comp looks ok, but just won't click. Thinking hinking more zip ties here.
To do;
a bunch of coolant lines and reservoir.
Clean mud from the backside of radiator, install fan.
Battery tray. I already had the aux battery bypassed. I may read up on how to remove.the cables since its all apart.
Air tube and box
Oil change and add coolant
Jeep Wrangler JL head gasket swap after P0301 code 1000170740
HHGadget
Gadget
Los Angeles
2018 JLU Rubicon
Man to think this started for you in September.
Way to stick to it brother. Can’t wait to see you posting back on the road.
Tip of the glass to you sir!
RenegadeT
RenegadeT
Tony
North Carolina
Can anyone snap a pic of where this ground line goes? Left front corner, I put it under the front bolt for the ABS?computer. Watching Nix Fix, I don't think he touched this module, and I don't see the ground line anywhere. Of course I cant find it in any of my pre-tear down pics either.
You can see the ground ring terminal in this old pic' after I removed the computer.
Jeep Wrangler JL head gasket swap after P0301 code 1000164100
Jeep Wrangler JL head gasket swap after P0301 code 1000170847
RenegadeT
RenegadeT
Tony
North Carolina
Copl thanks, that sure seems like it, and thats where I put mine, just didn't see it in the video.
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
By chance would you have a parts list, specifically all the seals you’re replacing? I’d like to compare to make sure I have everything on hand.
RenegadeT
RenegadeT
Tony
North Carolina
I used all OEM parts from AllMoparParts.com
The Mopar breakdown is confusing with a lot of overlap between different kit p/n's, so Benny set me straight. Here is what I went with...
68297850AC
Upper Kit [head gaskets, valve cover gaskets, spark plug tube seals, both upper/lower intake seals, + 2 mystery parts I didn’t find/use (1 possibly Throttle Body)]
68297851AB
Front cover seal kit [seals in timing cover, crank seal, water pump gasket, coolant manifold seal + 2 mystery parts]
68093232AA x2 Exh manifold gskts
4861965AA EGR cooler tube gskt
4893803AA x2 Oil control sol. seals (goes in valve cover, top)
5184772AB x2 Cam sensor seals (goes in valve cover, top)
4893806AB x4 Cam phaser seals (goes in valve cover, front)
4893926AH Thermo housing /stat (includes seal)
4893941AC Waterpump (seal/gasket NOT included)
68210345AC PCV valve (includes O-ring seal)
68082860AB RTV Sealer
I also replaced the oil cooler, which comes with new seals. Reuse the sensor.
68596318AB Oil cooler
or
68191356AB Oil cooler seals
RenegadeT
RenegadeT
Tony
North Carolina
Getting there. Nice weather yesterday, so I took a sick of work day and got a lot done.
I think all that's left is battery and its connections, oil change, coolant fill.
I misplaced 2 bolts for the air intake tube to radiator. Surprisingly I think thats all I lost.
I did not put the aux battery back in, so I will have do something with the cables. I have the ESS turned off via a Tazer, and have the fuse pulled. Negative cable between aux batt and main battery is removed and taped off. Will the positive cable at aux battery end ever get hot? Thinking I'll wrap it in electrical tape and maybe on old sock with another layer of electrical tape, then stuffing it back into the aux battery cavity.
Jeep Wrangler JL head gasket swap after P0301 code 20260107_173844
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
68297850AC
68297851AB
or
That’s very helpful and with notes too. Thanks!
JeepinPete
Pete
PA
'19 Mojito JLUR
Mechanical Engineer
Both cables can be removed completely with some tape cutting but would have been much easier before it was all back together. Even at that, doesn't take much to get them out. I know a lot of people just tape them off but I am not a fan of leaving unattached wires hanging around.
RenegadeT
RenegadeT
Tony
North Carolina
I really don't like taped off wires bouncing around either, so I cut some tape and traced the cables. Removing the aux ground was no problem; that is now gone.
Jeep Wrangler JL head gasket swap after P0301 code 20260111_141906
The positive is a different story. The aux battery terminal has 2 cables. One goes up to the fusebox (#1positon), but the second cable seemed to go into the bellhousing area in a big fat taped bundle. So it seemed like if I removed the easy cable, I would need a jumper from the #1 terminal to the cable running into the bellhousing abyss.
Not being comfortable removing partial harnesses and possibly making a jumper, I opted to tape of the positive terminal to aux batt.
Jeep Wrangler JL head gasket swap after P0301 code 20260111_110627
RenegadeT
RenegadeT
Tony
North Carolina
Am I done? Hope so...it fired right up!
Changed the oil, filtered out the red coolant I saved, installed battery cables and alternator cables etc.
The 2 screws "missing" for air intake tube were found with the airibox. Yay, no missing parts and nothing leftover.
Now I need to get more coolant for top off. This red/pink/purple compatibility conundrum is frustrating. When the weather warms up, i may flush what i have and add all new.
Final step will be reinstalling the aftermarket hood struts
Jeep Wrangler JL head gasket swap after P0301 code 20260111_123947
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
I still use electrical tape here and there but I came across self sealing silicone tape that I use in some situations. Waterproof and gives some padding too. It’s kind of a handy product to keep in the tool box.
RenegadeT
RenegadeT
Tony
North Carolina
Jeep Wrangler JL head gasket swap after P0301 code 20260112_075306
Rolled 60kmiles on the maiden voyage off to work this morning. Officially out of warranty lol. Everything was good.
Not so on the ride home. I was enjoying toasty hot air from the HVAC ducts, then it went cold and i wasnt enjoying anything. As I was processing that, the temp gauge went from halfway to full red. I quickly decided to pull off into the grocery store 1/4 mile ahead. The center display said something like HOT plus some more words i forget. As i scrolled the menu to show coolant temp, i passed thru oil and transmission which looked normal. Coolant temp said -- which i took as no coolant, sensor is in air.
So I pull over, pop the hood, notice coolant bottle is empty. There were definitely signs of coolant leaking, but i was surprised there wasn't coolant dripping everywhere all over.
Especially when I found a heater hose disconnected. The hose clamp was still on the hard pipe, presumably where i left it, allowing the hose to blow off.
Jeep Wrangler JL head gasket swap after P0301 code 20260112_174825
Pushed the hose back, on added the 1/4 gallon of coolant i had with me, then drove across the street to Advance Auto. Borrowed the worst slip joint pliers ever (I was missing my 3month old chinazon ratchet locking hose clamp pliers) and bought 2 gallons of coolant.
I got one full gallon into the Jeep, the drove it home (5mins). Let it sit during dinner, then got another 1/2 gallon in.
Im so glad I initially reused my old coolant!
Jeep Wrangler JL head gasket swap after P0301 code 20260112_193657
