Head gasket prevention?
ajbarbier
AJ
2018 Jeep Wrangler Sport S, 3.6
Hey does anyone know what causes the head gasket failures? Is it the faulty oil cooler? Radiator split? Under torqued head bolts? I’m trying to see if there’s any preventative maintenance I can do on my 2018- I only have 38k miles on my 3.6 and I’ve heard they fail at 50-75k :/
JayJLU
Jay
SE Pa
Wrangler, Gladiator, XJ Cherokee
Gee guess we were lucky, 120+K on ours and just started consuming coolant. No Oil Cooler failure either, No ticking either.
ajbarbier
AJ
What are you planning on doing?
alphawolff
california
2021 JLU
The "preventive" measure is damn near the cost of replacement. It's one of those things that just fails when it fails and you deal with it then.
ajbarbier
AJ
🫪 safe budget of 7k for a replacement do you think?
RoccoV
Rocco
North Carolina
2018 JLU Sahara
I have a 2018 and mine started leaking around 74k. Luckily I had an extended warranty and it was covered, around $4200. I was told it was a torque issue. Not sure to much or not enough.
ajbarbier
AJ
The repair would’ve been cost that much? What symptoms did you have?
JayJLU
Jay
SE Pa
ajbarbier
AJ
Putting a MOPAR Reman Long Block IN.. 3 yr / 100K parts and Labor warranty.
Huge. What’s the price running you on that?
I’m setting up a savings account lol
JayJLU
Jay
SE Pa
List price on the engine 6,100 book calls for 20 hrs labor. Estimates for doing gaskets and all associated would be in the 5,500 area .. No warranty beyond what the shops provided. Keeping the JKU For Ever; so this is less than buying another.
ajbarbier
AJ
6100 with labor included doesn’t seem bad at all!
ajbarbier
AJ
But that still stings quite a bit.
Blacksport
Ft Lauderdale
'25 Wrangler Sport S, 3.6/manual trans...'23 Corvette C8...'25 Yamaha XMAX
Not sure if I'm protecting mine, but I'm a firm believer these engines run too hot. Heat reduces emissions...great, but high coolant temp causes other problems. I've upgraded my '25 Sports S 3.6 with the Mishimoto radiator & 185° thermostat, and the RPM Extreme fan controller. I never see temps above 195°, and usually they're around mid 180s. Also, use a TRUE synthetic oil, with PAO & ester base, like Redline or Amzoil, not a "fake" synthetic, which are hydrocracked, refined dino oil. Maybe these help, maybe they don't, but they're fairly cheap insurance opposed to a replacement engine...
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I can't say this will prevent the head gasket from failing put keeping the motor running cooler with the RPM extreme JL fan controller is the way to go.
My coolant and oil temps are down by 25 to 30 degrees with the RPM extreme JL fan controller.
