head gasket swap after P0301 code
RenegadeT
RenegadeT
Tony
North Carolina
77 CJ-7, 99 XJ, 2018 JLR
Today I put new spark plugs in. When did the price jump to $12 per plug, wtf?!
Online sources said the gap should've been 0.043" and the plugs would be pre-gapped. Some of mine were over 045, some were under 040, so I tweaked them to 043.
Plugs torqued to 13ft-lbs in the head. Had to duct tape my 6" extension to the plug socket.
Jeep Wrangler JL head gasket swap after P0301 code 1000170469
Jeep Wrangler JL head gasket swap after P0301 code 1000170470
On to the valve covers, cleanup and knocked out the old seals. Each valve cover has 3 spark plug seals and 2 other grommets, 2 cam phasers on the ends and of course the cover to head seal. Replacing with Mopar OEM parts.
Jeep Wrangler JL head gasket swap after P0301 code 1000170472
I'm stuck on installing the driver rear seal. The locking lip of the seal is below the rigid upper section. The center part is flimsy and just collapses when I press from above. I can't seem to push/pull the lower lip to lock in. Ill give it another go tomorrow, but am tempted.to ignore this and hope whatever cam actuator goes in there seals it up when tightened down.
Jeep Wrangler JL head gasket swap after P0301 code 1000170474
Graphite JL
Romeo, MI
2018 Sahara Unlimited
Grab the Gearwrench sparkplug socket for next time. I bought one for doing plugs on my Hemi, it works on the 3.6. Plugs snap in, and has a wobble extension built in.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
$12 each is cheap compared to some. OEM Honda are closer to $40.
RenegadeT
RenegadeT
Tony
North Carolina
Cam position sensor seal.
My plan was to drop the seal in boiling water to make the rubber more pliable and maybe slide down where it's supposed to go. While the water heated up, I found a video that confirmed I was on the right track using a socket.of.the right diameter.
I had failed the day before with a chrome 1-1/16.socket Seemed.to fit great, but possibly a half a hair too small. The edge of the socket seemed to be wearing the inner lip of.the seal. I was pressing pretty hard.
So after the seal sat in hot water for a few minutes, I tried again. Same result, but i had another idea. While I pressed the inner lip with the 1-1/16 socket, I added a 36mm impact socket to help press upper top hat section of the seal into the valve cover, hoping to reduce any tension in the central portion that may be working against the lower lip from moving down. I also slid a 6" extension thru the 36mm socket into the other socket so I could force.both down. Seemed to work, so that was a good start of the day.
YouTube link
MotorCity Mechanic installing cam position sensor seal
RenegadeT
RenegadeT
Tony
North Carolina
Any idea what these seals are? They came in the same bag as the valve cover seals, both upper & lower intake seals, and possibly the spark plug tube seals.
Jeep Wrangler JL head gasket swap after P0301 code 1000170615
HHGadget
Gadget
Los Angeles
2018 JLU Rubicon
Just guessing but is the big one for the PCV on the back side of the passenger valve cover?
RenegadeT
RenegadeT
Tony
North Carolina
Nope. Hard to see in my bad pic, but these 2 mystery seals are flat with some bumps to center them in a groove, like the valve cover seals, or the ones in the timing cover/coolant ports.
PCV is a true O-ring. It was included with the new PCV valve.
Interesting to see the smaller hole in the new one
Jeep Wrangler JL head gasket swap after P0301 code 1000170471
HHGadget
Gadget
Los Angeles
2018 JLU Rubicon
Don’t worry you will stretch out that hole once installed :)
RenegadeT
RenegadeT
Tony
North Carolina
I bet the big diameter mystery seal goes between thrilottle body and upper intake. I did not, and don't plan to break these apart.
Here it is, easily slid over the TB input.
Maybe the smaller one goes in there too, on some solemoid/actuator.
Jeep Wrangler JL head gasket swap after P0301 code 1000170693
HHGadget
Gadget
Los Angeles
2018 JLU Rubicon
No i think you were right the first time as the nubs on it make me think it sits inside a groove on a piece. Like the other gaskets that came in that bag.
I seem to remember the intake manifold gaskets having those nubs no?
RenegadeT
RenegadeT
Tony
North Carolina
Oh....that explains why the new PCV valve didn't just "slide" in the back of the cover. That was a WTF moment yesterday.
Now that I look closer at the old one, I do see that the hole got rolled inward
HHGadget
Gadget
Los Angeles
2018 JLU Rubicon
Maybe it goes where the oil fill hole tube attaches to the valve cover?
(If that part is even removable?)
Jeep Wrangler JL head gasket swap after P0301 code IMG_4814
