Gladiator Fox shocks on JLUR?
Kevin Mojito
Washington
2019 JLUR Moijto 2005 TJ AEV Hemi
Do you know the extended/collapsed lengths of the Mojave shocks? If not, could you measure them when they arrive?
Fronts are :
15.750 - 23.750
Rears are :
17.750 - 25.750
They weigh 12.5 lbs each. Have 14mm bolts both front and rear upper and lower. They are no joke, full Fox Racing shocks. Not a made for Mopar and are missing something. They are bad to the bone internal bypass shocks.
Need to make some bushing/spacers and will get them on soon.
AnnDee4444
'18 JLR 2.0
Fronts are :
15.750 - 23.750
Rears are :
17.750 - 25.750
This is awesome... I can't wait to hear how this rides. Are you doing the Mojave front spring also (or any spacer lift)?
For those who don't know, the shock lengths are almost identical to Rubicon:
Front:
15.750" - 23.625"
Rear:
17.750" - 26.000"
Kevin Mojito
Washington
I'm currently on a set of synergy 2" springs, front and rear. I'll run the Mojave on those with 2" shock bracket.
The non tech feel of just smashing them by hand, they are in-between the JT Rubicon Fox and the stock JL Red Rubi shocks. But, they have internal bypass that kick's in at the top and bottom of travel. They really firm up the last 2" or so of travel, both top and bottom, both compression and rebound.
AnnDee4444
'18 JLR 2.0
That's good to hear. I was wondering how much it relied on the jounce bumpers, and the extra compression on the bottom 2" may be part of the equation.
Mac
MA
2020 Gladiator
I have a set of Fox JT Rubicon shocks for sale in MA in the classifieds if anyone is looking for a set.
Gregj
Greg
West Texas
Easiest way to make rear JT Rubicon shocks work on JL is to order and install the JT Rubicon front bushings in them.
Top PN 68274895AA
Bottom PN 68274045AA
I ordered these and while the top is correct the bottom is not. The outer diameter is too small see picture below,
Jeep Wrangler JL Gladiator Fox shocks on JLUR? 1609896213639
Hope this helps others, meanwhile i’m Looking for the correct one.
Gregj
Gregj
Greg
West Texas
To further elaborate on this, the bushings have the same part # but are clearly different. I am Able to insert the bushing with my hands, it is not a press fit.
I went ahead and installed them and they are an improvement over the red Rubicon shocks. They are much less jarring over bumps. I am ordering M14 bolts and nuts for the bottom mount and will reinstall the original bushings.
Now I am in the market for another set for the other JL!
Gregj
Warz2k4
RIC
New York
n/a
Gregj
You’re right, the bottom is push fit, and not press fit.
I installed them anyway, and it works fine.
Do you think I should remove it and use the proper bushing?
Gregj
Greg
West Texas
Idk, I ordered m14 bolts and nuts and will put the original bushing back in.
Gregj
Gregj
Greg
West Texas
I think eventually they will get loose and end up with a klunk in the rear end.
Gregj
Warz2k4
RIC
New York
n/a
Damn that would suck.
I have it bolted down to 80ft lb torque.
I hope it doesn’t get loose
Warz2k4
RIC
New York
n/a
Gregj
I'm thinking if we can order the JL Rubicon(or sport/Sahara) bottom bushings and install them on the JT Gladiator rear fox shocks.
