Flat towing or Trailer?
ktfjammer
Arizona
2018 Wrangle Sahara Unlimited
Having owned and flat towed 5 Wranglers over 85,000 miles behind a couple of Class A RVs....no issues or wear and tear...with trailers you have to deal with where to store it because most resorts don't allow you to keep empty trailers at your camp site....its a real PIA
I see you have a 2018 Sahara JLU. What wiring harness did you use? I read on a thread that it cancelled out his blind spot sonar.
Thank you, Jim
Jmonroe
Jay
2020 JLUR and a '99 Camaro SS convertible I bought new
I installed the Cooltech harness. The whole point is it breaks any connection to the Jeep while being towed. NOTHING on ours has been adversely affected.
dogbreath650
Bobo
06 LJ Rubicon
My LJR towed flat towed okay until I went up to a 5" lift and then it started getting squirrelly following me, a lot of sway, didn't really feel safe. But for closer to stock dimensions flat towing worked great.
Oldbear
Dwayne
Bowling Green, Ky
16 Ram 1500 Ecodiesel; 20 JL Sport S 2 door
My JL tows great behind our 28’ F450 based motorhome. No issues, works great.
JeepinJason33
Denver
We have had several different RV setups in the past. For serious wheeling, I like having the trailer as insurance in case something breaks on the Jeep and it can't be driven. This way, I can tow it home and fix it at my own garage rather than being at the mercy of waiting on a shop to fix it before I can return home. The other nice thing about a trailer is that I can chose whatever vehicle in my stable that I want to take with me on the trip. Flat towing generally requires vehicle specific tow bars.
Any campground that we are going to stay for more than a night requires reservations. We call ahead and ask about trailer storage and have rarely been told no. If we are, we just book someplace else. For quick overnight stops, pull through sites are big enough for us to get in and out of without unhooking.
Terminex
Omaha
2021 JLUR 4XE
Fixing stupid....
Thank you, Jim
I have been using the mopar harness to flat tow my Sahara for 2 years with zero problems. Blind spot systems works fine.
zrickety
Technician
I used a tow dolly for my YJ with no ill effects. Not sure why they recommend against it when the front axle can be disconnected 3 different ways. I would use it for the JL if I had to.
ktfjammer
Arizona
Did you install the harness yourself?
Thank you so much
Terminex
Omaha
2021 JLUR 4XE
Fixing stupid....
Thank you so much
Yes.
Hardest part was fishing the wires through the firewall. Use silicone lube on the wires when pushing them through, makes it much easier to get them to slide.
Down South
Sam
Louisiana
2020 JLUR
I used to trailer a car behind the motorhome. I visit numerous state parks and many private parks. Trailering is nice going down the road plus you can back up if needed.
One of the disadvantages of trailering is sometimes finding a place to drop the trailer. Once, I had to drop my trailer several miles from my campsite.
Another disadvantage is loading, tieing down then reverse procedure once you are at your destination.
If the weather is bad, "been there" it really sucks trying to load or unload then do something with the trailer.
Flat towing, I can be hooked up or unhooked within a couple minutes. And I don't have to worry about doing something with the trailer.
