Finally flexed it out with a forklift
UncleArt
UncleArt
Arty
Western Washington
2022 Wrangler JLR 3.6l, 6MT, 4.88s
Yeah, that looks like normal amount of bumps for that kit and the RRD shocks, my guess is that it reconnected on you….
This makes sense. Well looks like I got to see how much flex I get with sway bars connected!
UncleArt
UncleArt
Arty
Western Washington
Thanks for your help Rocky! Stay tuned until sometime next week.
Roky
Roky
Gorilla57
Chandler AZ
2019 JLUR Mojito
Yeah, make sure the front is moving. The RK setup flexes a ton, even with extra front bumpstop pads. I’m running 2 pads, any less and I’d really mash the front tire into the GenRight fenders. Tires already rub the fenders.
Jeep Wrangler JL Finally flexed it out with a forklift IMG_2171
Jeep Wrangler JL Finally flexed it out with a forklift IMG_2168
UncleArt
UncleArt
Arty
Western Washington
Thanks for this. As Roky said, I suspect that my sway bar reingaged when I turned the Jeep off. It’s the only explanation that makes sense. I do recall seeing the ends of the sway bar being on a similar plane as each other - and just didn’t think much of it in the moment.
Zandcwhite
Zach
Patterson, ca
2019 jlur
You'll never get the same flex out of a 2dr, wheelbase makes quite a difference in articulation. It looks like you should get significantly more, but it won't match the 4drs posted.
MaybeRubi
Wyoming USA
'24 JLU Willys 3.6 Auto Anvil
A bit off-topic, but the question came up from reading this thread:
I just got the apex autolynx sway bar disconnect. Above was reference to possible damage to fenders when articulated.
Q: Is there something I should be adding to reduce risk of damage to anything? I have a stock 2024 JLU Willys (Rubicon fenders are stock). It looks like the disconnects themselves will not pierce the inner fender, which is something the company discusses. Is there some other potential damage I should be aware of and mitigate? Just checking. (The danger of not reconnecting I know about.)
Thanks.
UncleArt
UncleArt
Arty
Western Washington
I flexed out the jeep again with the sway bar disconnected - for sure - left the engine running. (Even in 4lo, it reconnected with engine off!?) Anyways the results were much better.
Front 33.5” to bottom of fork
Rear 31.5” to bottom of fork
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3797
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3799
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3798
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3816
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3815
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3806
And thanks to @rocky and @Gorilla57 for the assistance the other day.
Beachcomber
League City
2018 Wrangler JL Sport
Yes.
I have read that even though it’s disconnected, there could be some binding. Not sure if this is true. The RK links are pretty flexible though…
Those pictures make me think it’s actually not disconnected. You should have way more flex than that.
UncleArt
UncleArt
Arty
Western Washington
I also trimmed the rear wheel well rear pinch seam - including cutting off the AAL lower liner bracket. At full bump, I just clear it now.
Before trimming:
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3758
After:
Jeep Wrangler JL Finally flexed it out with a forklift DED2CB09-E24C-416D-85EB-65E42A1CDD25
Jeep Wrangler JL Finally flexed it out with a forklift B8146492-9F27-414B-8980-88C6CD622F38
Jeep Wrangler JL Finally flexed it out with a forklift 932AC7D8-13BB-4165-8A55-DF54E137489C
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3802
UncleArt
UncleArt
Arty
Western Washington
Yep. It was definitely not disconnected on Saturday. Today, I left the engine running & achieved full stuff to the bump stops. See post 23
Roky
Roky
Nice!!! :rock:
Roky
Roky
Yeah, that’s a nanny that even the Tazer can’t get rid of…it’ll let you stay disconnected at any speed and even in 2wd but soon as the engine is off it reconnects…safety first….🙄
UncleArt
UncleArt
Arty
Western Washington
Tazer allows it to stay disconnected above 18mph?! Cool.
Roky
Roky
Yeah, you have to ( what they call remap it) which means make one of the cruise control buttons the new sway bar button..mine is the resume button….so as long as you use the new button to disconnect it will stay disconnected until you push the button again, no matter the speed….the resume button acts normally when the cruise control is in use…..
