Mopar Lift Kit - Shock hits spring perch when flexed
reldausa
Alan
San Diego
'25 JLUR Anvil
I have a Mopar lift kit enhanced with Spring correction pads, geometry correction brackets and adjustable track bars. Everything else installed is what comes with the kit.
I noticed that when fully flexed, the shock hits part of the spring and the pad.
Jeep Wrangler JL Mopar Lift Kit - Shock hits spring perch when flexed Screenshot 2022-11-09 at 2.49.26 PM
In this image you can see when fully flexed, the bottom part of the shock is making contact with the spring and it has actually detached the bottom sleeve of the shock.
Jeep Wrangler JL Mopar Lift Kit - Shock hits spring perch when flexed IMG_8582
In this image you can see the part of the spring perch where the shock makes contact:
Jeep Wrangler JL Mopar Lift Kit - Shock hits spring perch when flexed Screenshot 2022-11-09 at 2.49.13 PM
And in this image you can see the damage that is causing to the shock body:
Jeep Wrangler JL Mopar Lift Kit - Shock hits spring perch when flexed Screenshot 2022-11-09 at 2.49.01 PM
Any suggestions as how to fix? Do I need longer bump stops? Please help!
Thanks
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Is it just the picture, or are your frame LCA bolts off center of the bushings?
Jeep Wrangler JL Mopar Lift Kit - Shock hits spring perch when flexed D6F43647-97E8-4EAA-898A-B020314BA15E
reldausa
reldausa
Alan
San Diego
'25 JLUR Anvil
Remember its fully flexed so it must be the angle the picture was taken
Roky
Roky
Thanks
I used the EVO outboard brackets instead of the MC because I’m using longer shocks and didn’t want to sacrifice up travel……The MC relocates up 1-1/2” and out, and the EVO just pushes it out……Looking at your shock at full stuff, if you use the MC bracket, you’ll need to add bump stop to avoid over compressing your shock…. Here’s pic of the EVO brackets……..
Jeep Wrangler JL Mopar Lift Kit - Shock hits spring perch when flexed 10CD6FC4-9E2D-4AB1-ADAF-E63A963749F3
Jeep Wrangler JL Mopar Lift Kit - Shock hits spring perch when flexed 6C011CB6-3DF4-4CC5-B90E-6DCCA3C764CD
GATORB8
CLT NC
Just a thought, 1 hole up on the UCAs may be enough to keep them from rotating the top of the axle so far back.
reldausa
reldausa
Alan
San Diego
'25 JLUR Anvil
Thanks so much!!! I will take a look at them.
reldausa
reldausa
Alan
San Diego
'25 JLUR Anvil
Thanks so much, will check it out also
