GATORB8
I'd be careful before tossing the factory jack.Exactly... My factory jack won't even reach my differential hardly.
Grab a bottle jack from Lowe's or, even better, grab a hi-lift jack and install appropriate armor with hi-lift jackpoints.
I keep forgetting to take my factory jack out... this thread was a good reminder
No way in hell I'd use a high-lift to change a tire on mine. I'd have to get a slider like 40" in the air, bumper would be even higher, and I'm not sure I'd even be comfortable at stock heights. I had one fly when I was on my initial 1.5" and 35s setup.
You'd have to be really selective on a bottle. You've got to get under an axle tube at like 6" with a flat (with no tire, that's half a 17 minus half an axle tube). Then you have to get it up with clearance to mount the spare (in my case, half of 37 minus half an axle tube) call it 17". Hard to find a bottle with those specs, remember, you can't always dig a hole for the jack (say in rock) and driving up on a rock to get clearance means lifting the axle at an angle.
I use the stock scissor with the Mopar base (similiar to the ARB above). Although some of the posted scissors definitely look like good options.
