Engine coolant level?
Ormond Beach, Florida
Retired at 55 ..
Went to dealer, they only had concentrate, so I bought and diluted exactly 50/50, yet it looked purple compared to my pink reservoir. Is that ok? I threw it in regardless only because I needed so little. Probably only added 10-12oz or so. (Still have a lot of the mixed solution in that jug leftover)
Thanks in advance
@Respo
Did you mix with distilled water? Did you read through the posts in this thread?
JimLee
'19 JLU
Thanks in advance
It'll be fine, soon enough it'll be the same color as the rest.
jlroman2
Jorge
Chicago, IL
2018 Jeep Wrangler JLU Sahara (Granite)
BCBA
Had to add to mine. Was pretty low. Added almost an entire cup. At 48k miles
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
I remember back in the day adding something like coolant was not rocket science, all we did was pick up a jug of Prestone and mix it 50/50 and keep the res tank at least 1/2 full we never used turkey basters or any exact science of measuring coolant.
I to have fallen into this trap as well but anymore after washing my Jeep ( once a week ) I just visually inspect all res tanks and check oil and look for any leaks and as long as the tanks and levels are not dropping I move on, life is to short to worry if my coolant tank is a 1/4” higher or lower than it was yesterday.
HeavyUser
CO
JL
It's a car forum guy, the OCDs are everywhere.
entropy
Foothills of the San Gabriels
OF top 1% content creator
I think my coolant's viscosity is not right. Seems a bit too viscous. I don't know. I pumped a little bit off the tank into a completely air tight container to avoid possible contamination. Then I took a sample of water and something just doesnt feel right. I might take a sample to the lab to get the exact viscosity of the fluid. Could also be the PH of the water I am using to compare with. The other night I couldn't really sleep, my wife was driving the Jeep and all I could think was the engine exploding or something. Any ideas? Wish me luck guys.
zakaron
Pittsburgh, PA
2021 Willys 4dr, 2004 Pontiac GTO, 1986 Honda Nighthawk S
Sounds like somebody put headlight fluid in your coolant reservoir by mistake. You’ll need to do a complete flush of the coolant system - make sure you also reverse flush the heater core to ensure all headlight fluid is removed. When you refill with the proper mix of coolant and distilled water, check the mix with a squeeze bulb tester sold at parts stores to get the exact mix required by your climate area. I wish you the best in getting this resolved!
blnewt
New Mexico
Just ask @cosine he knows!
Retired at 55 ..
blnewt
New Mexico
Price Drop Alert...
For those that need coolant the correct coolant, it can be had at Amazon.com for a very good price today... $17.50 .....
On Amazon, it usually runs about $22-23 per gallon. Stealership will want $25-$26 for it.
It's 50/50 Prediluted, so do NOT add water to it!
https://www.amazon.com/gp/product/B017DP43ZC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I got my full concentrate mopar coolant for $18 gallon at the dealer, maybe the buddy I have behind the counter got me the inside deal??
ALRUI
Arnold
Murphy, NC
2018 JLU Sahara, 2003 F150 S-Crew FX4, Others
Sounds like you got a great price for sure!
Retired at 55 ..
Prices for the coolant have gone up and down these last few months.
Right now prices for it seem to be down but local Mopar dealer's (stealerships) are still asking more then most. Seems with dealer's price it depends lots on where you reside/the stealership you buy from.
And yes, the employee at the dealership can often do you a solid and give you an additional 10% off.
With that said $17.50 with Amazon Prime free shipping is an aok price and a few $ less then over the last few months. Better then paying $22-25.
