Engine coolant level?
jhern88
Jay
ILLINOIS
2019 WRANGLER SPORT JL 4 DOORS V6
@jhern88
Per FCA....
Flush and replace the engine
coolant at 10 years or
150,000 miles (240,000 km)
whichever comes first.
The one i have says 5 years and is color pink, so how many mileage should i change mine?
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@jhern88
You say "I have says 5 years" Where are you reading that?
What I posted was found in my Maint. Schedule from FCA for a 2018 JL. You'd figure you are using the same pink coolant in your 2019.
The bottle of Mopar 68163849AB Coolant says 10 Year/150,000 Mile Coolant.
Curious....Why are you worrying about changing coolant on a 2019 JL ?
jhern88
Jay
ILLINOIS
@jhern88
Today went to jeep dealer and buy the coolant says 5 years and this color is pink, this what i have now in my jeep. The ten years is purple.
Rhinebeck01
Retired at 55 ..
@jhern88
What is part # of coolant you got from the dealer?
The Mopar 68163849AB 10 Year/150,000 Mile pre mixed Coolant is bright pink.
https://www.amazon.com/gp/product/B017DP43ZC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Again, pre-mixed is bright pink. If you order the non-diluted product, it will look almost purple. Properly diluted, it will look bright pink.
Next time buy on Amazon as it is less expensive there. I go with the pre mix but you can also buy concentrated there.
Rhinebeck01
Retired at 55 ..
This coolant is pink and the part number 68163849AB, this one is color purple why is that?
@jhern88
Pre-mixed is bright pink.
Be sure if you buy concentrated to use distilled water when diluting/mixing!
Be sure your JL, is stone cold lets say when adding coolant.... using levels marked on reservoir.
jhern88
Jay
ILLINOIS
@jhern88
So that coolant is new and clean, cause 10 years of not changing coolant is way to long right?
I think ones a year is good right? Is it easy to change coolant in 2019 jeep wrangler sport jl 3.6 automatic myself? Also what is the part number for coolant for my jeep. Dealer is charging $200.00 for this coolant and i think is to much.
Rhinebeck01
Retired at 55 ..
@jhern88
Do read over this whole thread...
There is no reason you need to be thinking changing the coolant in your 2019 JLU. No reason!
Perhaps in 5 or more years from now, put not now...
FCA, is putting in 10yr. / 150,000 mile coolant for a reason....
All you need to do is occasionally/as needed, top off the coolant reservoir...
Use the Mopar 68163849AB 10 Year/150,000 Mile pre mixed Coolant which is bright pink. Use this pre mixed product and then you will not have to worry about mixing with distilled water.. Just shake the container and use.
The least expensive place to buy this Mopa premix coolant that FCA, recommends for the JL/JT is on Amazon..
ALRUI
Arnold
Murphy, NC
2018 JLU Sahara, 2003 F150 S-Crew FX4, Others
Rhinebeck01
Retired at 55 ..
blnewt
New Mexico
Just ask @cosine he knows!
Andrew
Greer, South Carolina
2018 Jeep Wrangler Sports S Unlimited 4 door (3.6L 8 Speed)
my coolant fluid sits lower than the picture shown above, i was confused and came here to confirm if others were having same issues, and as i can see from the other post it seems to be common for 2018+ JL/ & JT Wranglers as well. i let it sit cold air and still continues to see the same level, will try drive around for 30+ minutes and see where the fluid sits at. my jeep is reaching at 30k miles and will be doing ATF/ Transfer Case fluid change soon, probably will check on the coolant as well.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Just top it off. No big deal.
jhern88
Jay
ILLINOIS
Max is to the line below the word. Minimum is to the big joint of the reservoir tank.
Where is the bolt under radiator to flush coolant for 2019 jeep wrangler jl sport 3.6 ?
