Drop in kill switch, no splicing
azjl#3
North AZ
Apexcars
North Texas
2020 RAM 1500
I wonder what is the problem with this system and the e-torque and the Stop/Start feature? Is it that the car won't start back up when you take the foot off the brake at a light if you don't have the Stop/Start button on the dash pushed? What about if you have the Stop/Start button on the pushed to turn off that feature if the Mobilistic system will still work? It should be just a simple relay for the starter system with a radio controlled function that opens and closes a contact point in the relay.
I hope the Mobilistic system will work if I have my Stop/Start Feature button pressed in on the Dash. I always disable the Stop/Start feature when I start up the vehicle. Occasionally, I forget to do that.
Anyways, I ordered one and I am going to give it a try and hope that it will work the way I hope it will.
Why not just reach out to them and ask. I would assume it has something to do with hooking it up to a 48 volt system instead of a 12 volt system but I didn’t try to look up anything about it. I doubt it’s the stop start though because non etorque Jeeps have that too.
Nokones
Kenny
Sun City West, AZ
I tried to reach to them both email and a voicemail message and so far, there is no response.
JeepinJason33
Denver
I used the one @maestro5531 makes. It is the stop/start kill switch and installed really easily. You pick out your own switch.
azjl#3
North AZ
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Membrain
Dirk
DFW TX
'21 XR392 / '24 XR392
Engineer
yeah but, by defenition, if they hack your keyfob, they got this thing broken as well.
I plug it in and lock it, then I unplug it and hide the OBD connector. It stays locked until I know to reconnect it if/when I want to get under the hood.
JeepinJason33
Denver
au176
WNY
2021 Islander, 2020 Newmar Ventana, 2014 HD Road King
Tired again
Please let us know if it works...
au176
WNY
Tired again
Ditto. $30 shipped and as effective as the installer's ability to hide the owner-supplied SPST switch.
I'm assuming a JL Start Button? If so, I'm dropping $30 plus an SPST, as long as it works with E-Torque!
JeepinJason33
Denver
I have a 2021 Etorque, the start stop button is the same regardless of the Etorque or not.
