Differential Oil
Radioman
Kent
Roseville, CA
2017 Toyota Highlander, 2020 Ford Ranger, 2025 Jeep Rubicon
Retired Public Safety Communications Manager
Would this work in rubicon?
https://a.co/d/cuzQONi
My owners manual says:
Front diff 75W85 GL5
Rear M200 75W140 GL 5
Rear M220 75W85 GL 5
My Rubi came with M220 rear diff. I would use the Valvoline show as long as it is listed as GL 5.
Along with discussion of motor oil, tires, etc., there will be others that disagree but I would use the 75W90.
Edit; I would use a synthetic 75W90 from Mobil 1 or Pennzoil, etc. in addition to the Valvoline.
If you have oversize, non-OEM tires, consider using what the axle manufacturer recommends, to get the maximum load performance that Dana specifies. If your jeep is stock and you use it lightly, carry on with the light viscosity gear oil Jeep recommends.
UTME
T
2024 Rubicon-X Unlimited
Interesting northridge sells the Dana diff covers with royal purple 75w140
Jeep Wrangler JL Differential Oil IMG_8584
Jeep Wrangler JL Differential Oil IMG_8585
Jeep Wrangler JL Differential Oil IMG_8586
DRVMN
Clearwater, Minnesota
2026 Jeep Wrangler Willys 4-Door
If you add differential oil with friction modifier and your Jeep does not have the limited slip differential, will it hurt anything other than you maybe paid more for a higher end fluid that you didn't need?
autotragic
the cornbelt
'21 JLR 6MT
Count me as the odd man out: I stick to OEM recommended spec and use Redline 75W-85 GL-5 gear oil front & rear in our Rubicon and Amsoil SG 75W-85 GL-5 gear oil front & rear in our Grand Cherokee.
The problem is when you say OEM recommended spec...
Which OEM are you referring?
For instance if you listen to Jeep and the owner's manual they'll tell you that you're automatic transmission has lifetime fluid but ZF who designed the transmission says it needs the transmission fluid changed at 60,000 miles.
Same deal with the axles, I'll continue using 75W140 in both axles because that's the Dana spec not Jeep's fuel economy spec.
When you say OEM this distinction matters.
autotragic
the cornbelt
'21 JLR 6MT
The one that makes, sells, & warrants the vehicle.
Jeep didn't make your vehicle though they just assembled it that's what I'm getting at here.
If you want to listen to Jeep fine but I'm going to listen to the actual OEM not the assembler.
jadmt
jeff
montana
I contacted Dana Spicer and they told me to follow jeep's recommendations...
jadmt
jeff
montana
no it will not hurt anything.
Kracka
Christopher
Oak Point, TX
C8 Corvette, 19 KL Trailhawk Elite, 23 JL Rubicon
Yes, they assembled it after all components were made to their spec. Their spec calls for 75W-85 and as noted above, Dana says to follow said spec. Spec after a rebuild is a different story...but that's no longer OEM. Much like how a built engine needs a different weight oil vs. stock.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
The OEM of the differential or of the vehicle? Why?
Heimkehr
Pennsylvania
2021 JLU 2.0T
No, nothing will be harmed. Ring and pinion gears will be present no matter what, meaning the friction modifier would have to be compatible with them no matter the presence, or not, of LSD hardware.
Many over-the-counter gear oils have the friction modifier as a default ingredient.
DRVMN
Thank You! That makes sense and I appreciate your explanation!!!
wanderer
Ralph
Carlsbad CA
Engineering Geologist
What about in hotter? Weather is a 75 140 better say temperature ranging from 80 to 100+ ??
