Auto Start Stop disable options?
SoK66
Jerry
Durango, CO
Jeep Gladiator Sport (3)
Unless your intention was to be "humorous", this is (FOR ME) simply a BS advise, as I do not know anyone who can meticulously remember and press that button EVERY time they start their car...
There is always a distraction around, sometimes it is a coffee in your hand, sometimes kids at the back, grocery bags, partner getting in the car, pedestrian around your car... etc. etc. PLUS, why would someone needlessly do this action thousands of times for the lifetime of their Jeep?
Just because this can be done and in fact it was designed exactly that way to function, there is absolutely no reason to advertise it as a "solution"....
Works for me every time. We have five '21 Gladiators in Jeep Tour service. I trained our tour guides to do this so we can prevent burning up the starters and placing unnecessary loads on the batteries. It works.
Often the best solutions are the simplest.
X35
PA
2025 Wrangler Willys XR
@Nash_Dj Agreed. There’s just some members on here that don’t like having choices they don’t agree with.
In my case I operate several different vehicles throughout the week. My Jeep is the only one with the ASS button. I’m not going to remember to hit it every time so I dropped a hundred on Smart Stop Start device. If someone else thinks I’m lazy or spending money recklessly I don’t give a shit 😉👊🏼🍻
Jeep Wrangler JL Auto Start Stop disable options? IMG_1470
Nash_Dj
Nash
Burnaby, BC Canada
(R.I.P.) WILLYS 2021; Hello 2025 - Mojito JLUR
Works for me every time. We have five '21 Gladiators in Jeep Tour service. I trained our tour guides to do this so we can prevent burning up the starters an unnecessarily loading the batteries. Often the best solutions are the simplest.
So you simply accept whatever you trained your employees to do is automatically and absolutely every time done that way?
Good for you...
Tyler-98-W68
Tyler
Canada
2021 Sahara 4xe, 2022 Rubicon 4xe
Just curious what data you have that ESS burns up starters.......its been around on Jeeps since 2015......and I haven't heard of mass starter failures.........nor have I heard of mass battery failures on ESS equipped jeeps that don't use the ESS batteries.
Malpaso
New England
JL
New JL owner here, is disconnecting the "hood sensor plunger" under the hood not recommended?
Nash_Dj
Nash
Burnaby, BC Canada
It works, but you will have the warning light on your instrument panel always on, and this is annoying for many people... If you can tolerate it, it is OK. The better way is any third party device - I use Tazer as it can change/adjust a ton of other settings, too...
Richard_JL
Larry
Boca Raton, FL
2026 JLU Rubicon 3.6L
IT Director
The most reliable & economical method is right after you press the button to start the engine reach to the right and press the button on the dash to shut off the feature. No cost, no dice roll with the electronics, just works.
Dice roll? A little dramatic maybe.
Yeah, I'm sure you remember to push the button every time.... like the rest of us, at the first stop light when the V6 shudders to a stop and the A/C blows warm. ;)
Nardulli
St Louis
2021 JLU Rubicon Diesel
I’m looking to disable this and have done some research on the options. The two devices I have found are the Tazer products and the smart Start Stop Device. Are there any other options? I read JScan won’t do it.
Pull the fuse (I think it is #42) and disconnect battery cables to the AUX battery. No more ESS and no codes.
Nash_Dj
Nash
Burnaby, BC Canada
Here we go again, just merely a month since we debated here and debunked this topic...
WHY people continue to provide advices that are not true, or half truth???
What you wrote is a process to eliminate the AUX battery from Jeep's electrical circut, but will NOT automatically eliminate/disable the ESS feature...
One still needs to either push the infamous button every time the vehicle is started, or use the third party electronic device that will "remember" the last state of that button...
Nardulli
St Louis
Well, my 2021 JLUR diesel appears to be unaware of the fact that this process should not work. NO ESS, no codes. If I scroll through the menu it shows ESS not available, battery charging.
onepoundjeepjl
Robert
youtube.com
2023 Jeep Wrangler Sport, White
Engineer
Not recommended for a few reasons!
what are the few reasons? i never thought it was bad except for the stupid light on the dash. I have it pulled right now....🤷‍♂️🤦‍♂️
X35
PA
The main reason why it’s not recommended is that it can mask other issues by having the warning indicator on all of the time. If disabled with tech and the stop start not available light comes on it can be an early warning for a week battery. Other than that I ran mine with the sensor unplugged for a while without any issues.
onepoundjeepjl
Robert
youtube.com
Engineer
ok thanks. yeah I wasnt thinking that there were many reasons for that light to come on.
  • Like
Reactions: X35
