2021 Auto Stop Start Disable by disconnecting auxiliary battery negative cable?
Paulguy100
Wisconsin
2021 JLU Rubicon
So I pulled fuse 42 and disconnected the auxiliary battery negative cable. The JLURD now uses the main battery for start stop. I thought pulling the fuse and negative battery cable would make it go away?
Flip
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Make what go away?
You should be good now. ?
Flip
Virginia
Oh wait, do you mean you thought the auto start/stop would go away meaning you wouldn't have to push the button to disable it every time you start the vehicle? Nope!
But don't you fret none brother, all you do now is a little on-line shopping, plug this little rascal in and you'll never have to worry about that pesky ESS again, and trust me bro you did the right thing by disconnecting that confounded lawnmower battery, that problem will have surely, bit you in the a** someday.
This little device that works flawlessly is worth every penny. Mention you're forum member and I think you get a discount. $99. Best of luck bro ?
https://www.smartstopstart.com/jeep-dodge-chrysler-products.html
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
+1. The start stop start is first class. You still have the “capability”(?) of start stop if you should want it, BUT it stay where you put it. Push the dash button to turn it off and it stays that way?. I’ve had mine for a couple years and wouldn’t be without it.
Paulguy100
Paulguy100
Wisconsin
2021 JLU Rubicon
As others have said, you'll need a device to disable it. Either get what @Flip mentioned or spend a bit more to get a crapload more functionality with a Tazer.
I have the Tazer but was hoping to go back to “stock”. Maybe I can plug in the Tazer and just not “marry it”.
Zandcwhite
Zach
Patterson, ca
2019 jlur
The tazer will remember your ess setting, traction control settings, show you to adjust tire size, disconnect the seat bar in 2wd or at any speed, use lockers in 4hi or even the rear locker in 2wd, among other things. I wouldn't own a Rubicon without one. What is the gain of "going back to stock" you're eliminating the aux battery and the start stop which isn't "stock" anyway.
Paulguy100
Paulguy100
Wisconsin
2021 JLU Rubicon
I had some electrical problems, not related I’m sure, but wanted to go a month too see if anything popped up. Otherwise Tazer is great, except for poorly written instructions written by a 12 year old.
DonBindas
Don
Naples, Florida
Ordered a 2020 JL Rubicon Unlimited in Bikini with Dark Saddle Leather on 7-8-19 and was delivered by Criswell 8-22-19
KBB Analyst
I got a memory relay interrupter from Amazon for something like $35.00. So now, when I push the button on the dash-it remembers to keep the Start/Stop in the off position until I decide to push the dash button to enable it. It works great and it's a 5 minute or less installation! I noticed that the price on Amazon varies on a daily basis-as I only paid $32.00 for mine.
Citreal Autostop Eliminator for Jeep Wrangler 2018-2023 /for Jeep Gladiator 2020-2023
Jeep Wrangler JL 2021 Auto Stop Start Disable by disconnecting auxiliary battery negative cable? Citreal Autostop Eliminator for Jeep Wrangler
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
I know what you’re talking about. It is a pain to start with. But I have owned 3 vehicles that had this. I just hit the button on the dash and roll on. Just not a big deal when you get used to it.
