Audiophiles... a word...
AnnDee4444
'18 JLR 2.0
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Be happy you didn't buy a Bronco, I hear even their "premium" Bose system is garbage... :CWL: :CWL: :CWL:
Had the premium Bose system in a Mazda and while far from perfect, it just sounded a lot cleaner and more tonally balanced than the Wrangler's premium Alpine system imo. Probably a lot to do with better speaker placement and a significantly quieter cabin (Wrangler isn't as bad as I was expecting, but the sharp angles of the hardtop and interior certainly aren't helping anything). Usually not a fan of Bose home audio gear, but this setup really wasn't too bad for a stock system.
Opus
Opus
Midwest US
www.jlwranglerforums.com
Thanks all for the feedback (no pun intended). You've given me some settings to try. As for XM, I like the variety and the fact that it's currently free with my new Jeep. When it comes time to start paying for it, I'll likely live with local HD radio channels and my iPhone. I have too many subscriptions sucking the life out of me as it is...
azjl#3
North AZ
exactly which song I use, great base licks, perfect highs.
On a related note, no pun intended, I am researching getting into a digital walkman, the 600 to couple thousand variety. Getting tired of the all music all the time Serious, turning into the DJ has a chance to talk for 5 minutes between songs. not why I pay for the subscription.
Btw btw, while I use the XM, i use the phone with BT to the radio so I can select quality of download. Jeep XM sounds like a tin can and a string.
Beachcomber72
2022 JLU High Tide
Connection to phone with a dedicated cable usb-c will yield the best possible sound. As much as possible in our vehicles. And Apple Music would be your best music source for lossless audio and higher.
five9dak
PA
Bikini '20 JL Freedom, '99 Dakota R/T, '11 Boxster
2DR soft top with alpine.
I run the bass -2 or -3 and the mids and highs flat. I move the bass up or down a bit depending on the genre. Usually -2 for dance/club or hip hop, and -3 for everything else.
With the EQ flat, as delivered the bass was really peaky for me. I have a pretty long torso, so it might be my seating position compared to where it was calibrated at. I haven't measured it.
My source is usually an android phone running Pandora through the USB to android auto.
  • Like
Reactions: AFD
west tex
Skoro
2021 JL 2dr 80th Edition, 2017 Renegade Trailhawk
Retired, as in "Tired again"
I set the bass +1 mid flat and treble +1
Works for my aged ears.
AnnDee4444
'18 JLR 2.0
Agree about the bass being peaky (at least for the 2-door). Try flat bass & adjusting the fader forwards. The sub is on the rear channels, and the rear speakers can't handle the higher volumes anyway.
Cyber_Jeeper
2022 JLUR
I believe I’m at +3, -2, and +2.
I can echo the disappointment with the XM. FM sounds better than XM, XM doesn’t work in my local canyons (where FM stops working and XM would be helpful), and the DJ’s need to talk less and play more music.
Opus
Opus
Midwest US
Right now I'm at +2 / -2 / +7 and it's sounding pretty good on most of the songs I'm listening to.
Trav73
Travis
Washougal, WA
2021 Jeep JLUR
AusJeepNoob
Sydney, Australia
2020 JL Wrangler Unlimited - Rubicon EcoDiesel
Looks like I'm the exception rather than the rule in this thread. I've got bass maxed, mids a -1 and treble at minimum. I also have the fader a couple of clicks towards the front so that may be impacting the bass output hence needing to have the bass turned up to max. I've also put polyfill in the sub enclosure. This is all temporay however....
I had a simple SQ system in a previous vehicle that would score 18s and 19s at comps. I still have the front splits that I ran in that system and am going to be installing them along with the rest of the gear I've cquired in my JL around Christmas. I've got the Rockford Fosgate DSR1 for signal processing with 2 x MB Quart NA2-400.2 to run front and rear stage with sub bass being provided by a Deaf Bonce DB3512 in a custom box tuned to 32HZ powered by a Taramps Smart Bass 3. It is going to be LOUD :rock:
Gaust
Todd
Portland, Oregon
2018 Wrangler JLU Rubicon, 2018 Renegade Trailhawk
I’m a music lover, ex professional audio installer, and a live audio engineer. Had the non Alpine, system till I upgraded. I’ve got the oem 7” radio connected to my phone using the usb c and Apple Lossless.
The only upgrade from that would be a Cck3, into something like a Smsl po100 or Topping d10s, into a dsp, like a Helix, with digital input. It would be a digital signal from your phone or source to dsp.
