Aluminum knuckle failure
Chocolate Thunder
Jeremy
When I ordered my RCV axles in Feb, they said 12 weeks out for delivery. That will put me around May when I tear it all apart. I went with the FAD two piece version. I’m not sure if the one piece has a quicker delivery.
Where’d you order them from that said 12 weeks for delivery?
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
Retired LEO
It was on RCV's website. I originally ordered them through Northridge 4x4 with the 10% forum discount in Early Feb. I checked with them last week and they said may be shipping in 5 weeks. I ended up cancelling and going to Poly Performance again to save on the sales tax and shipping.
Baba Yaga
NJ
www.youtube.com
Retired LEO
Hey Jeremy,
Blanket delay verbiage on their site now.
Jeep Wrangler JL Aluminum knuckle failure logo
FREE SHIPPING for orders over $75*
*Some restrictions may apply
During this time, RCV Performance working to fufill orders as efficiently as possible. Please allow for some additional lead times on all orders and warranty claims until further notice.
For all questions please email [email protected]
For more information CLICK HERE
NOTE: FedEx has suspended Delivery Service Guarantees until further notice. As a result, we are currently unable to compensate any shipping costs in the event your order delivery is delayed.
benny_rt2
Benny
Baton Rouge Lousiana USA
1989 YJ - 1999 TJ - 2004 TJ
When i order my new jeep I plan to also order some basic upgrades including Reid racing knuckles, better balljoints and chromo shafts (probably CV) as part of the initial investment. Do it fast, like removing a bandaid.
CarbonSteel
Despite the general dislike for FAD, eliminating it on a JL/JT creates a different problem. Here from Adam's Driveshafts:
Due to Jeep changing their angles on the JT and JL Models, if you install an After Market Differential or Axle Kit that Eliminates the [FAD] front axle disconnect and the driveshaft spins full-time, it may result in a vibration and/or premature U-joint and CV failure.
Rsarffs
Socal
2021 wrangler unlimited rubicon, 15 rzr xp1000
Looks like breaking an axle u-joint with steering clocked forces pressure against knuckle and breaking at balljoint boss weak point.
Baba Yaga
NJ
www.youtube.com
Retired LEO
Yes, that appears to be the general consensus.
jessedacri
Jesse
Lake Arrowhead, CA
2019 Bright White 2dr JL Rubicon 3.6
There's no solve for this? The JL is fundamentally not able to lose the fad and have an aftermarket driveshaft that doesn't wear prematurely? I feel like the angles aren't crazy far off from other stuff out there, am I missing something here?
I have an Ultimate 44 axle up front that doesn't have a fad and the stock FCA driveshaft does not vibrate, the CV side flange is all bent up though from being at full flex a lot and I need to replace it soon. Hope to go with something that isn't going to vibrate, that's for sure.
Baba Yaga
NJ
www.youtube.com
Retired LEO
I'm thinking its hit or miss on an aftermarket DS and Adams has to put that out there for the possibility of vibration on a live axle. My $.02
CarbonSteel
The angles on the JL are much "tighter" than previous versions--but it could be the UD44 improved those angles, but that can depend on the lift height too. I can say that when I had issues with the DS CrMo axles where they seized between themselves inside the FAD and the driveshaft turned all the time, there was a ton of vibration that I'm sure would have caused premature wear. Aside from that, the vibration was not tolerable for long distances. I'm glad I sorted it with RCV axle shafts. I personally like the FAD and wanted to keep it.
Baba Yaga
NJ
www.youtube.com
Retired LEO
I believe the ponytail Asian Youtuber has your axle and was fine with an aftermarket DS.
bjm00se
JLUR 6sp ordered 11/3/21, picked up 8/30/22
The owner of the Jeep and some here are linking "not using lockers" to the bouncing.
I'm with you on being unlocked not necessarily being a *cause* of bouncing.
But in the presence of asymmetric bouncing, with lockers not engaged, the unloaded wheel can pick up more wheelspeed, and thus have a lot more rotational kinetic energy that can be translated into causing damage when the bounces end and the wheel loads up again.
gato
New England
2021 JLUR
Agreed.
But conversely, when unlocked the load from a wheel that suddenly lands and gains traction (chock) is mitigated by the open diff offering - i.e. the open diff allows for, well, different speeds between the two wheels/axles shafts. When you are locked, you make everything into a mechanical connection with no play - when one side stops the load goes solidly everywhere - one component will loose.
bjm00se
Agreed.
But conversely, when unlocked the load from a wheel that suddenly lands and gains traction (chock) is mitigated by the open diff offering - i.e. the open diff allows for, well, different speeds between the two wheels/axles shafts. When you are locked, you make everything into a mechanical connection with no play - when one side stops the load goes solidly everywhere - one component will lose.
Yep.
As usual, the situation on the ground determines the outcome.
Folks who "always turn on their lockers" or "never turn on their lockers" are oversimplifying.
Right tool for the right job at the right time.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Dana is welding the inner C's according to Jeeps caster specification. Since many of us are finding better handling with more caster, that's putting the pinion at a lower angle. Couple that to a lifted Jeeps increased driveshaft angle, and vibration becomes a concern at highway speeds and a locked front axle in 2h.
I opted for the 2-piece RCV axle set to avoid that likely vibration. I have zero inclination to ditch the FAD until I upgrade to a larger set of axles with manual locking hubs.
