AEV 2.5"
JimmyR75
Ryan
Tennessee
Current: 2014 JK — Previous: 2004 TJ, 1994 YJ
thx for your info.. very good reference before making decision on lift kit
Trail Recons video
Probably one of the most important things to remember with that video is that the AEV kit is designed for loaded Jeep’s, not stock with no added weight beyond the driver. He mentions that, but it’s hard to make an apples to apples comparison.
Hucke_250
Ohio
2018 Unlimited Sport
I Installed the AEV Dualsport 2.5 lift last weekend on my 2018 JLU Sport. Considering this is the first time installing a lift (previous cars were lowered with coil overs) installation was straight forward and I did not have any issues. I am really happy with the ride, handling, of the AEV lift. I do have a Clayton front track bar ordered to re-center the front axle.
Thanks to everyone who has participated in this thread, it really helped with my decision on which lift to purchase.
Wheels and tires are 20x9 +1 Fuel Rebel 5 and 35x12.5x20 BFG KO2 wheels.
Jeep Wrangler JL AEV 2.5" 9C97663D-595C-4F51-AAD4-8CF35C276576
somedude922
McFrisco
2021 JLUR, Previous: 1984 CJ7, 1979 CJ7
So after installing this lift, my caster is very low (4.1) per the alignment shop. I just want to make sure I have the caster plates in right. I set them for the highest lift. Which should give me the most caster right? I did order the mopar lift LCAs, so maybe that will help once I get them on.
Jeep Wrangler JL AEV 2.5" 427F0A91-B211-4F6C-BB5E-765FF8622DE7
Jeep Wrangler JL AEV 2.5" 38479547-BD67-4A93-99A3-4BBF49028741
hoag4147
Colleyville, TX
2022 JLUR XR
Haven’t read much on this lift and trying to see what the orientation of washer does to the UCA. Does that position pull UCA more to rear of vehicle or push it more forward? If pushing forward will definitely give you less caster.
somedude922
McFrisco
I believe it pulls it more rearward.
Hucke_250
Ohio
somedude922
McFrisco
@somedude922
Here is a thread I found where @voland and @Kurt0 are using both geometry brackets and longer lca’s.
https://www.jlwranglerforums.com/fo...ection-brackets-for-2-lift-recommended.48550/
I’d reach out to them for specifics or maybe they will chime in.
I have my washer set to the 2.5-3 inch lift. I won’t know if this is enough or not until my alignment scheduled late May.
My longer LCAs arrive tomorrow and I will get them on next week. Thanks for your reply. I will post back when I get them on and get an alignment !
Hucke_250
Ohio
Let us know. I’m really light with plastic bumpers and soft top. I wouldn’t be surprised if I’ll end up needing adjustable lca or mopar lca’s as well.
somedude922
McFrisco
Mopar lift LCAs brought caster to 5.5. Handles much better.
hmnshee
Dubai
2019 Wrangler JL Unlimited
Thanks to everyone who has participated in this helpful thread, it helps me to decide the lift kit that i will purchase in future because the sponsor of AEV in my country said it will be available after 4 months :lipssealed:
my questions here
the lift kit is enough or i should buy track bar ? and LCA from Mopar ? or track bar is enough to adjust the caster ?
if i got 3" and more shall i change drive shaft or no need ? my jeep is JL Unlimited Sport for ur info
your advise and replay will be more helpful guys
lordcon
MD
2020 JLU Sport S
my questions here
Your front axle will be off center slightly after changing the suspension geometry from the AEV lift. Maybe by 3/4 inch or so. I have the AEV lift and installed a Steer Smarts Yeti front track bar to correct it back to center.
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
I ended up going with the mopar, just because the reviews/suggestions I got said it would ride a little better on the road than the aev. I cannot say whether it does or not. I can say it rides okay with 37s, but they need Aird down. I did add the Rc adjustable front track bar, and adjustable front lower control arms. It wonders a little at highway speeds, so I just ordered an adjustable rear track bar, relocation bracket and rear upper/lower control arms (Clayton’s :)
Hope that helps. I don’t think you can go wrong with either, based on reviews.
JeffK
Pa
06 Ram 2500 5.9 2019 JLU Rubicon
How is the bowing on the front springs?A lot of people with the mopar lift had to get a set of correction pads from RK or other company to fix the Bowing issue.
