Adjustable control arm clunk
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
I have a set of rough country adjustable lower front control arms that have zurks and one seems to be moving. I’m not sure if it’s just doing it because I need more grease. The bolts are tight. Probably 4k miles since grease. Is that normal?
limeade
Guy
Reno, NV
What exactly is moving? The bushing, bolt, the zerk fitting?
If the zerk is moving, you can tighten it.
Otherwise, if the control arm is moving, then one or more of the bushings is bad. Unfortunately, you get what you pay for when it comes to Jeep parts (and most everything else). Rough Country is not a company known to sell high quality parts. If it were me, I'd throw them in the trash and buy quality control arms from Rock Krawler, Metalcloak, Clayton, or Rock Jock.
Caliguy
Norcal
2022 Rubicon JLU
Core4x4 makes some great ones! And in different colors too. If you get the highest one you get metal Johnny joints. They don’t go bad, just keep them greased but can be a bit noisy(creaks a bit if not driven for a few days)
Roky
Roky
Control arms shouldn’t move at all laterally, grease won’t tighten them up either…sounds like it’s time to hit up Northridge 4x4 or River City Offroad……. If you want to pay extra, tell them I sent you……. :LOL:
Northridge4x4
Summit Sponsor (Level 3)
Silverdale, WA
www.northridge4x4.com
2016 Sahara JKU, 2013 Rubicon JKU
Seller of badassery
And if you want to save money, use the forum discount code: jlwranglerforums ....;)
@kapk22, When you say one is moving, what part is moving? The shank where it is threaded into the arm, at the joint or at the bolt?
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
If you put your Jeep into 4low and step on the brakes you can shift from forward to reverse and the pinion will wrap up and down putting force on the bushings. Have someone you trust run through reverse and drive and check out what's going on. You can watch the pinion without getting under the Jeep. You can get under there and check. Just don't get ran over and think twice if your SO is the beneficiary on your life insurance policy.
kapk22
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
Bushing part, frame side Not the threaded part. The arms only have maybe 8k on them. Crazy. I have Clayton’s on the rear. Maybe it’s time.
Northridge4x4
Silverdale, WA
Seller of badassery
kapk22
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
I can move it back and fourth by hand. It only moves a tad, but it’s enough for me to hear and feel inside while driving.
I’m really surprised the bushing would fail so fast. The roads around here do suck though. And I just made the 2400 mile trip to Texas. I’m sure the 37s don’t help either.
Now I am concerned about the rough country track bars on her. I don’t have the money to replace the arms right now, so I will have to deal with the periodic clunk. It’s not bad, it’s just a little annoying.
kapk22
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
Got them on Saturday. It seems like the road manners improved a bit. Might just be my mind playing tricks on me.
Jeep Wrangler JL Adjustable control arm clunk 830DED71-A47D-43C6-929B-17C7F9314118
