LukeDagny
- Apr 20, 2024
- Central PA
- 2021 JLUR
I recently installed a Clayton Offroad lift kit on my JLUR. I'm really happy with the quality of the components. It included adjustable upper front control arms. Clayton give guidelines for what length to set the control arms and track bars, based on lift height. Per the instructions, this is a starting point, and additional adjustments may be necessary.
I measured caster before/after installation. After installation, my caster was about 1 degrees less than original. I did a test drive and wanted to add a little caster. My thought was adding one degree put me back to stock, adding two degrees would be even better. I shortened the upper front control arms, two full revolutions. With a 1-14 thread pitch, two revolutions is slightly more than 1/8". This increased my castor 2 degrees. Going forward, my rule of thumb is one revolution equals one degree of caster.
What are other peoples experiences when changing control arm length? Upper or lower? With my LJ, I had double adjustable control arms, and adjustment was easy. With adjustment at only one end, its a little more time consuming.
