4wd Lo is Jerky Jerky
Turniipp
Utah
2021 JLUR 3.0
So, in reading the various responses, I can't help but wonder how many folks have driven their 3.0 in 4lo extensively. I have and I know exactly what the OP is taking about.
My experience has been that uphill it's buttery smooth. Downhill is buttery smooth. However flat below 5th gear can be a jerky mess as the throttle is so dang sensitive. If the trail allows, I'll try and get it above 5th, if not, you can place your right foot on the transmission tunnel so that it's half-on half-off the accelerator. This allows the friction between your foot and the transmission tunnel to smooth out your acceleration.
I've been thinking about looking into a Green Diesel Tune to gain more power and to see if they can do anything when it's in 4lo.
If you have a Rubicon Diesel in 4lo, it's a 4:1 ratio and instead of 400+ ft/lbs of torque, it's exponentially higher and touchy.
I am on 37's and I have regeared to 4.56's.
Grayhound
Michigan
Jlurd
I am on stock gearing with diesel Rubicon, and 35s and can confirm when in 4low transmission feels very jerky between gears. I have found manually. Shifting is my best option in 4 low, unless I'm about to run up a hill and then I'll run up the hill in automatic until I have to throw it over in manual for that last little nudge over the hill.
Jeep Wrangler JL 4wd Lo is Jerky Jerky 20250519_124257
flick2614
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
So it's not just me being crazy; that's a relief.
flick2614
flick2614
Randy
AZ
I have one brand new in a box if you want it? It was replaced under warranty and i didnt re-install it as im going a different direction with my tune. Had that and the Derringer (will also be selling) in mine for awhile.
Wrote you a direct message.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
I'm on 37s with stock gears. I have a Derringer and a Pedal Monster.
No real jerking with the throttle when going all over Moab.
21JLURDG
Bill
Olympia, WA
2021 Wrangler Unlimited Rubicon 3.0 Gecko
I'm drive the 3.0L on 37s w/4.56 & 4:1 T-case getting ready for 40s but drove extensively on 37s w/3.73. I previously drove a 4.0L TJ on 38s w/5.29 & 4:1 T-case.
I'm not sure what your 4x4 experience is like but I've always found the low gearing on 4L to be very "jerky" and learned to drive with the right heel on the transmission tunnel (as previously mentioned) to control my throttle inputs. I'm now used to it and can drive it smoothly regardless of terrain, but it did take practice.
One additional thing that I didn't see mentioned is the use of Off-Road +. While in 4L (4H is different function) the OR+ button is designed for rock crawling and will dampen the throttle sensitivity and the engine acceleration while holding a current gear longer (tends to feel like over-revving). I've learned through experience that it works great crawling over large rocks, but it can hinder wheel speed when trying to generate instant acceleration to climb a rock wall. Driving on a straight level trail it will rev the engine before giving a hard shift--somewhat annoying.
BDinTX
Dallas, Tx
Man it took to almost the end of the first page to get all the details.
With 37"s and 4.56 gears I'm not surprised it feels jerky.
Us po' folk with the original gears find 37"s to be just fine.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
And yet it doesn't feel jerky at all for many of us with 37s and 4.56 gears.
My usual thoughts are "Damn, this thing's a beast!" while my peanut gallery chants "Go Jeep, Go!".
Grayhound
Michigan
Jlurd
I have found that I don't enjoy offroad+. manual shifting in those scenarios is working best for me. I'm normally going slow enough to not need a lot of shifting.
Rogersocal
Roger
2020 Rubicon Recon 2.0 turbo, 2018 Ram 2500 6.7 TD
There was an issue with the transfer case engagement; it popped out of 4hi, I adjusted the linkage, it popped out of 4lo, so I adjusted the linkage again. The little dog ear used to adjust is a horrible design in my opinion. But I'm fairly certain the engagement is solid as in the uphill example feels solid.
Strange, I can sometimes be in 4low and it will pop out, there is something that can be adjusted to make this not happen? please explain.
BDinTX
Dallas, Tx
flick2614
flick2614
Randy
AZ
C.Sco
2023 4xe Rubicon
All factory equipped diesels came with 3.73 gears. Even the Rubicons.
I haven't regeared and on 37s I'm well below 2,000 RPM at 75 in 8th gear.
Learned something new today! I had no idea. I'll see myself out of the diesel forum lol
